TimW
2. I am presuming miniDSP needs to be connected between the audio source/DAC and the integrated amp:
Model 1
Source/DAC==> miniDSP==>Integrated Amp==>Speakers, with the subwoofer being connected directly to the miniDSP
Is this correct? Or is it linked after the Intergrated Amp?
Model 2
Source/DAC==>Integrated Amp==>miniDSP==>Speakers & Subwoofer
What I was suggesting is closer to Model 2, but not exactly. You see the pre out and main in connections on the back of your NAD Integrated amp? Right now they should be bridged together with some links. Those links can be removed and that separates the preamplifier section of the unit from the power amplifier section. Then you can connect the pre out to the inputs of the miniDSP 2x4 and connect two of the 2x4 outputs to the main in of the NAD. This way all of the controls on the front of your NAD will still function properly. The other two outputs of the 2x4 should be directly connected to your subwoofers.
With this setup you won't want to use the headphone output of the NAD because it will be affected by the corrections and high pass filter performed by the miniDSP. This is because the power amp section of the NAD directly powers the headphone output, which is not ideal as others have pointed out. Thankfully the tape out is part of the preamplifier section so it will not be affected by the miniDSP. So it would be a good idea to use the tape out with an external headphone amplifier.
