Affordable Accuracy Monitor Review
tw 2022
YeongGyun An
i think it could work , but i'm no expert..... @ryanosaur would probably know for sure...
After listening to your opinions and thinking hard, I decided to buy this because I think the most similar thing to denim insulation sold in Korea is insulation made from recycled clothing.
The thickness is 0.4" in inches and it is 35.5"X393.7" 19.22$.
I'll have a lot left over after I use it, but they don't sell it in a smaller size than this, so I decided to go with this.
Thanks for your help and answers.
The speakers are used and I spoke with the seller and will pick them up next weekend.
It will probably take me a month to buy the parts and modify them.
I'll leave a review after I do.
tw 2022
very nice... i think it will work fine... @ryanosaur probably didn't respond because he had nothing to add... i'm looking forward to the review...:)
alexis
This is where DIY truly is fun and exciting. You can pick any components and try them. All would work. :)
HighFutility
I just finished one speaker; it took too bloody long. The curved sides would constantly have drip marks. I had to cut the poly 50/50 with paint thinner and apply extremely light coats. It took about a million coats to build it up high enough. I used high gloss polyurethane, Varathane brand. Wet sanding the orange peel was also tricky, but I got it done.
USER
View attachment 362867View attachment 362868
That's awesome, man. I've put together a couple of these as gifts and wish they looked half as good. The looks now match the sound quality. Great job!
@Dennis Murphy you have to take a look at this!
