Affordable audio interface for sonarworks mic?
turbotuff
Hi there I was wondering if you could recommend an affordable audio interface to be used with the Sonarworks mic for room correction. Unfortunately my UMIK-1 won't work with sonarworks, so I need to use their XLR mic which requires an audio interface with +48v Phantom Power and 44.1 kHz sample rate capability.
All help is greatly appreciated! Thanks!
AudioStudies
How much is affordable? Would a portable recorder like the Tascam DR-100 MKIII meet your needs?
Matias
São Paulo, Brazil
turbotuff
turbotuff
This is the error code I get when trying to use my UMIK-1 with Sonarworks. I believe the bit rate is incorrect with the UMIK, as it is locked at 48k, and Sonarworks requires 44.1k.
