Veri
- Joined
- Feb 6, 2018
- Messages
- 9,599
- Likes
- 12,041
Hmm, what unit number is that?Topping has a new one with the 4499ex as well, same unit number just one ess and one akm
Topping E70 VelvetHmm, what unit number is that?
Found it thanks! https://shenzhenaudio.com/collectio...-support-dsd512-pcm768khz-decoding-e70-velvetTopping E70 Velvet
sad face for me - I just purchased E70 L70 stack a week ago... for sure, I can't tell the difference between these two dac chip, but I'm curious about how "Valvet" it sounds.Found it thanks! https://shenzhenaudio.com/collectio...-support-dsd512-pcm768khz-decoding-e70-velvet
Makes the E70V-A70 stack pretty tempting for people in the market right now, I guess
I mentioned for me the AKM dac is my favorite. I’ve heard them all. Implementation is key so you can’t truly says.sad face for me - I just purchased E70 L70 stack a week ago... for sure, I can't tell the difference between these two dac chip, but I'm curious about how "Valvet" it sounds.
I very much appreciate the detailed information!I mentioned for me the AKM dac is my favorite. I’ve heard them all. Implementation is key so you can’t truly says.
But to break it down in my perspective it’s like this:
Burr Brown/TI warm/dark spectrum absolutely not edgy/digital/sib
AKM same but toned down warmth and much more details are present vs BB. Sound gets sharper basically
CS chip is neutral with more detail present going towards ESS’s sharpest sound. I think I need to hear more CS chips, to give a conclusive result
ESS is basically ultra detail oriented and what some may consider as bright. Super clear and transparent. Also probably the least musical/warm/dark of the dacs.
I’ve been interested in the x26 pro but it’s pretty pricey and I love my D70s which has two 4497’s. Also the Monolith AC Liquid Platinum which uses the 4499
I’ve had 3 ess dacs and I did not like two of them absolutely. Too crisp for me, my Volumio primo has one and it sounds quite pleasant honestly. I stream direct from its internal dac quite a bit
My last 2 DACs were ESS Q2M series based so not even the expensive 'Pro' chips and I really don't hear the least 'musical/warm' thing you say... I remain sceptical. My CS(Cirrus Logic) basic macbook and meizu dongle don't really sound different from it either. Just 'good'. Lol.ESS is basically ultra detail oriented and what some may consider as bright. Super clear and transparent. Also probably the least musical/warm/dark of the dacs.
Looks like @WolfX-700 already measured it too!Found it thanks! https://shenzhenaudio.com/collectio...-support-dsd512-pcm768khz-decoding-e70-velvet
I feel you, your audio chain may have influence on it. Just equally as my results. I do not feel it's drastic, I just hear a difference.My last 2 DACs were ESS Q2M series based so not even the expensive 'Pro' chips and I really don't hear the least 'musical/warm' thing you say... I remain sceptical. My CS(Cirrus Logic) basic macbook and meizu dongle don't really sound different from it either. Just 'good'. Lol.
My Audial TDA1541 DAC sounds darker/rolled off but that's because it has very little filtering as a design choice. It's based on an old 16-bit converter. Any proper designed DAC should not sound drastically different from another. I would say 'IMO' but it's hardly an opinion, it's also what the science around D/A conversion would dictate..
Maybe it's only so apparent because the noise floor is so low...?Now we have 2 implementations of the new AKM chipset and see a Hump. So, no technical competition to Ess anymore?
Sure, a low noise floor makes it more visible, but the situation with a similar floor seems to be more or less solved in some ESS implementations. The I/V section is still not easy to design.Maybe it's only so apparent because the noise floor is so low...?
Almost all CD players and DACs up- or over-sample, often to the maximum admissible rate. Benchmark is an exception, (currently) choosing to up- or down-convert everything to 211kHzThere is no music even close to anything like this as far as I'm aware, so what's the point?
I do not see a hump on the Gustard unit. Honestly though, not sure if this is factorable, but at this level of performance with sinad is that even a factor? isn't the hump a product of distortion or noise, not sure which, but clearly none of it should be audible or maybe it is.Now we have 2 implementations of the new AKM chipset and see a Hump. So, no technical competition to Ess anymore?
post#30I do not see a hump on the Gustard unit. Honestly though, not sure if this is factorable, but at this level of performance with sinad is that even a factor? isn't the hump a product of distortion or noise, not sure which, but clearly none of it should be audible or maybe it is.
https://www.ap.com/technical-library/imd/ still could not get a precise understanding from this
Not getting much information for SMPTE either o.o
Burn in knowledge = learning.Burn in intermodulation distortion..?
