AKM restarting production
dlaloum
There is NO human who can hear -120dB and beyond... on this planet at least.
In other words... yes! Totally pointless after that.
It is plenty useful when you are recording, and don't know what the peaks might be, or the troughs - you try to get the amplitude centered on your dynamic range window - but you might have it wrong! - one peak too high and the recording is toast - a trough too low, and it gets lost in the noise floor...
An extra 20db is a very valuable commodity!
Also when ripping / archiving vinyl... sadly the pops/clicks are very large in magnitude - so you have to allow circa 20db above what you expect the peaks of the recording to be, to allow for those - as if the pop / click goes over the 0.5db point then the distortion impacts the entire frequency range...
Once recorded cleanly you can process it, delete the clicks/pops, and adjust the levels - so you record in 24bit even though 16bit (96db dynamic range) would be more than ample... in a perfect world you would record using 32 bit giving you dynamic range of a theoretical 1500db (!?!) - 24 bit is supposed to be 144db in theory - but as you can see looking at specs, it is very rare to find an ADC that even achieves 120db.
But yes - beyond 120db is useful in various recording processes... but not so much in playback - and quite ironically, we can achieve 130db in playback, but usually barely get to 110db in recording!
Gradius
Iquique, Chile
I'm talking specifically on hearing (playback).
Hearing isn't just about noise floor... it's a lot things.
Few humans can hear 19kHz~20kHz at all. If you have more than 18 years old, you can't hear beyond 17.4kHz anymore (and only gets worse as we age).
About recording... we have plently PRO Studios recording at full 24-bit (over -135dB), they normally record in 32-bit now as it's pretty useful for software manipulation. I don't know where did you get that -110dB myth.
For example, a very CHEAP stuff (less than $3k), can record @ -120dB, like this one:
Keep in mind as tecnology advances, you will NOT find beyond -100dBish from old recording (around 20 years and beyond). This is just as expected.
Also, music in general has loose a lot QUALITY (as music) since ~1995... so I don't see your point.
