Am I ruining my sound with insulation?
Snoochers
I have a 9.2.6 system in a 16x25x9 home theatre. Long story short I have a front wall with left, center, and right channels and these are surrounded and backed by 15-25" of insulation. See the photo below. A screen goes in front of the speakers. The insulation was placed based on the following assumptions:
1. Reflections off the front wall in a home theatre are generally bad (correct, I think).
2. Materials that only absorb high end frequencies are problematic as they disproportionality impact the high end. Therefore, thicker materials that absorb lower frequencies are preferred (correct, I think).
3. I had tons of material (true), so why not
4. "baffle" walls for home theatres are a common thing so surrounding speakers with insulation can't be that bad (don't know if correct)
5. The majority of sound from speakers comes from the front, so having insulation behind or around them isn't a big deal (don't know if correct)
FYI the subwoofer is ported and the driver and ports are facing the center speaker in that gap.
I'm wondering if I messed up here with this system.
Is placing insulation so close to my speakers a problem? Should I just remove a lot of it to free space?
How does insulation so close to speakers effect frequency response and dispersion or other qualities? Data from actual measurements would be especially helpful!
Beershaun
Hi. Have you tried taking seating position measurements with and without the insulation in place? REW with a umik-1? I think this would give you the definitive answer and give you a tool to measure any room treatments you put in place and the affect they have.
Jdunk54nl
Arizona
Is your screen that you use acoustically transparent? I know your other thread had some REW data that was not great.
You are definitely getting very little bass reinforcement below 150hz and a lot of high frequency issues (Bad screen choice could easily cause that).
https://www.audiosciencereview.com/...uld-i-be-looking-for-in-rew.25445/post-865812
Picture from other thread linked above, for what @Snoochers thinks is L+R but it didn't seem like he 100% knew that.
Jdunk54nl
Arizona
This blue line would be the harman target (there is variation that can be with this curve, this is just generalized like Amir does it for the predicted in room response). Obviously this can be shifted up/down depending on where you start, and usually a lot of people like more bass than this too.
Here it is slightly down, with, what I would consider big, problem areas boxed in red.
S
Snoochers
Thanks for this. I will take some measurements later today and post them. These previous measurements I’d take with a grain of salt since both speakers were likely playing at once, which I know can skew things a lot. I also need to move the mic around I think. And I can look at my EQ settings.
is the general idea that insulation is OK if measurements look good?
does it not affect directivity or anything? I can’t measure that with my mic for sure
RayDunzl
Central Scrutinizer
Riverview FL
Maybe.
Left, Right, and both here, mic centered at the listening position, uncorrected:
With DSP correction. The dip at 48Hz is standing wave phase cancellation at the listening position due to asymmetrical rear of room.
Yeah, the target was "flat".
Jdunk54nl
Arizona
Just remember, multiple speakers playing together should be louder across all frequencies.
If you have cancelations caused by multiple speakers, something is off.
RayDunzl
Central Scrutinizer
Riverview FL
Both of those situations are present in my measures above.
Add 6dB for both speakers playing the same signal, and the cancellation at 48Hz for both speakers that is not present with either left or right singly.
S
Snoochers
I don't know if I should be replying here or in my broader REW thread, but I took some more measurements tonight. ARC GENESIS shows me the general curve I'm aiming for (but haven't tinkered with much) while REW shows me something very different. Thoughts? I'm using the ARC microphone.
Jdunk54nl
Arizona
Does the arc microphone come with a calibration file? If so is it loaded in REW?
Are these moving microphone measurements or single spots?
S
Snoochers
I've been doing some reading and no it is not calibrated for use in REW, which means anything above 1khz gets sketchy. I've tried moving the mic and being stationary, no big difference.
Now I'm wondering whether I should get a UMIK-1 or say forget it and just run ARC and hope it is good.
Jdunk54nl
Arizona
I don't see the cancelation by multiple speakers in your graphs? All of your together is louder than single speakers, except where you apparently have room/something cancelations (in single speaker and in together measurements), but those are not multiple speaker issues.
Jdunk54nl
Arizona
Usually low end and high end is where the biggest correction areas I've seen in "cheap" measurement microphones. That is also where your two graphs differ the most.
S
Snoochers
Are you suggesting the Arc Genesis microphone from ANTHEM is not good? I haven't heard that before and the manufacturer and such seems reputable and obviously the amp cost 4000$ lol.
I could just get a UMIK-1 but if I recall correctly I might need to buy it from a special place that calibrates it? Or can I just buy it anywhere?
RayDunzl
Central Scrutinizer
Riverview FL
The ARC software may contain a generic "calibration" for the microphone that goes with it.
REW would not have access to that calibration and would show the raw response of the mic, which may not be very flat.
A calibration file tells the software how much to adjust the readings across the frequency band.
Example calibration curves (adjustment) for a group of UMIK-1 measurement microphones (which are reasonably flat uncalibrated)
Jdunk54nl
Arizona
No, not suggesting that at all. But all "cheap" microphones need calibration files. Almost every Avr has the calibration files built in.
I say "cheap" because even the eathworks microphone capsules are like less than $10. But their other sorcery and time makes them worth more. They come with calibration files, but usually they are really flat out of the box.
S
Snoochers
Yes so the question is do I need to buy another microphone for use with REW or should I simply be confident in knowing my anthem receiver Is EQing well?
S
Snoochers
Jdunk54nl
Arizona
That is a question only you can answer. Is it worth it to you?
If you do go that route, I'd suggest a motu m2 or focus rite 2i2 interface with a Dayton emm-6 microphone.
You can do a lot more with that setup than a USB microphone. Biggest benefit is easy loop backs. Then you can run Open Sound Meter.
