Amazon Music to Mac Mini will not play above 24/48kHz - any trouble shooting tips?
Jaimo
Jaimo
Toronto, Canada
Yeah, that old Intel MacBook is a jalopy compared the the M1. It's amazing how far Apple silicon has advanced in just a few years.
I use a M1 based MacBook Air for note taking. The MB sits next to my work issued Lenovo i7 laptop. Although the Lenovo is a great machine by PC standards, it is nowhere near the MB in terms of quality of build and ease of use. My family's Apple computers tend to outlast our PC's easily with twice the useful life of the many Dell, Acer and Asus machines we've had.
My Mac-mini music / movie player is almost 10 years old and shows no signs of ageing whatsoever.
Zensō
California
So what price convenience? So far I hear no discernible difference in sound quality with Sound Check enabled.
I guess, theoretically, Sound Check could raise the noise floor a bit, but I can’t imagine it would do so to an audible level. The more important question, I think, is whether or not it’s effective. I’ve found that in some cases it actually seems to increase volume discrepancies instead of reducing them, as if it’s over compensating. After experiencing this a few times I’ve mostly left it turned off. It has been a while though; I should probably give it another try.
tmtomh
Thanks! And yes, Sound Check is notorious for using a crappy algorithm to normalize the volume between different albums/tracks. That's why I use iVolume, as it replaces the default Sound Check volume adjustments with ReplayGain ones, which are more accurate/perceptually sensible.
