Amir's Music Server Build Thread
g29
My 3 comments.
Nothing wrong with disabling unnecessary features or not loading them in the first place (keeps registry and disk clean). First thing I have always done after installing Windoze is to disable all of the Windoze GUI "eye candy" features to optimize it for performance. I don't need GUI animations on my work or music machines.
Second, use Thesyscon's DLP Latency Checker to see if anything is holding onto resources too long that would cause audible glitches.
Third, use multiple SSDs. 1 "small" drive for OS, 1 or more larger drives for data.
majingotan
Laguna, Philippines
Nothing wrong with this if you're using an incredibly old machine for music playback. IMO this is ineffective in today's computers and especially Windows 10 though if you want the highest PCMark/GPUMark, game benchmarks, this is a must though
g29
What do you base that assumption off of ? Freeing wasted memory and CPU loads is noticeable on even Intel Core I7 machines.
If you make a music PC that resides in your music room, you use passive cooling and no moving parts as well as no overclocking to keep the machine absolutely quiet and stable. Passive cooling implies the use of a low TDP CPU. If you are just doing playback that is one thing, but if are doing realtime software DSP, transcoding and convolution, that is another.
ousi
California
Speaking of streaming devices, I recently found Zotac USA is dumping the CI320 (passive cooling) at 47.99USD. This barebone takes DDR3L SODIMM (8GB max, one stick only) which is cheap, and accept SATA 2.5" drives (also cheap).
I got one and stuck in a 4GB RAM stick (19USD) and a 960GB SATA SSD, put Volumio x86 on it (fully functional since the hardware is couple years old), connect to a SMSL M500 and I got a one(two)-box solution. I was running Volumio with RPi4B with a 512GB microSD which I ran out of space, not to mention the couple years old amd64 hardware is still way faster than the RPi4B.
I don't really like playing from network (hence I want large storage capacity without dangling wires) so YMMV but a full-on 64-bit x86 platform for 47.99USD is hard to pass, especially it's passively cooled and quite compact.
somebodyelse
Used thin clients often go for <£20 with fanless x86_64, 2-4GB RAM and similar SSD, sufficient for daphile, volumio etc. A lot of them will take an internal 2.5" SATA drive. Some of the newer ones have USB3 ports, but you might have to pay a little more for those.
krabapple
Where are you seeing this deal? All I see on the Zotac site (and on ebay) are refurbs.
jeff57
hi Amir
I am curious... Why did you chose the path of building our music server (a silent pc) ?
It would have been easier to pick a silent NAS (I have one from Qnap).
I got a silent Qnap, put a SSD disk in it, and I control the music with an ALLO Digione player and my smartphone.
No fan. No noise. And quite cheap.
ButI dont use Roon !
Jeff
In the cold
Nice PC!. I used to build a lot of PCs myself, however for some years now I find laptops do everything I need. As it is switched on most of the time, I do find the lower power consumption of laptops beneficial.
Low end Acer, about $350 AUD IIRC manages Roon core and Jriver for video serving just fine.
I thought about building a HTPC a few times, and everytime I ended up with a cheap laptop as the best (price/performance + silence) solution.
Harmonie
France
Sounds great, I have to keep that post :cool:
Chromatischism
Replying to OP:
Brings back memories. I built my current PC in January of 2016 using the same CPU and Samsung 3D NAND SSDs. It's not a fanless build, but it is pretty quiet (water-cooled).
I'm sure this build is still going strong today.
I'm thinking about upgrading my 2010 Synology NAS to a newer model using the same SSDs. It's still running the 1-2TB Western Digital HDDs I put in there 10 years ago! It serves my music and accepts my automated weekly backups. I've been telling myself for the last couple of years "if it's not broken, don't fix it"...
Sal1950
The Chicago Crusher
Central Fl
Ha, that's a spring chicken. I built this box in 2008 and it still runs fine but I do worry over its age. I've updated the drives to most all SSD, took out a big fast GPU I had and replaced it with a fanless unit, also installed a USB 3 pcie board for doing my backups. I'm looking at replacing the power supply with a fanless model soon. I'm wondering how close I can get this guy to running totally fanless and not go up in smoke. The big test will be trying to get the CPU to run fanless, doable but ------------
‎Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
zenmastering
I ran essentially the same processor, fanless, for years in a studio machine that ran 24/7. It's still running now as a file server. I used a monstrously big heat sink ('cooler', if you must ;->), properly mounted with heat sink compound. Power supply was fanless and the spinning drives were mounted in heatsinking cases; all as quiet as you'd imagine and it sat in my studio control room where noisy things are verboten.
So, I'd say go for it...
At some point, I ran a variable-speed fan, set to really slow, when the air conditioning in our studio crapped-out; still no problems or noise irritation. I could occasionally hear the drives seeking, which is, of course, a total non-issue with SSDs.
hi Amir
It was based on availability of Room EQ. I found Dirac which ran on Windows so went with that. I have a Qnap NAS but find its interface unrefined.
Sal1950
The Chicago Crusher
Central Fl
Don't know what you'd refer to as "a monstrously big heat sink". I run a Arctic Freezer Pro rev2 using Arctic silver 5 paste. A pretty good cooler in it's time.
capitanharlock
My 3 comments.
in my opinion this sw isn’t Good anymore for modern Os, I.e. Windows 10.
it was abandoned by the developer loooong time ago.
Latencymon for example.
Hipper
Herts., England
My current PC set up uses something built on the lines of Computer Audiophiles CASH systems, made by Quite PC in 2013. It uses the same Streacom casing as you use.
At that time it seemed that noise filters on the hard drives (both SSD and HDD) were recommended:
https://quietpc.co.uk/sotm-sata-noise-filter?product=2989
Did these do anything, or anything worthwhile?
I wanted to run Dirac Live EQ and it was only available for Windows.
Did you consider JRiver and its PEQ and GEQ? I have JRiver but haven't used the PEQ yet as I'm listening only on headphones but I'm moving more to the idea of using a PC source for my speaker set-up which will require it.
I have a 21" monitor I can actually read and a handheld track ball for navigation of the music players.
I've not heard of a handheld track ball mouse before and like the idea - I'll investigate thanks.
Hipper
Herts., England
Should of course have said 'Computer Audiophile's CAPS systems'...
Tom Schofield
Why not just use a laptop? I was looking at an Asus on sale at Costco for $499, which allows you to reverse the display so that you could set the motherboard side flat on your stand and have the touch screen display standing up for use.
