AMP/DAC Combo Recommendation for HD6XX
eXodus
Looking for recommendations on an AMP/DAC combo for my HD6XX. Looking for something with XLR balanced..
I'm looking at the Monolith THX 788 and the Monolith THX 887 and heard about the THX 789.
Not sure what to get, it seems the 788 has XLR IS NOT balanced? Looks like the 788 XLR IS balanced?
Open to similar suggestions on amp/dac combo. This is my first AMP/DAC purchase.
twsecrest
California
E
eXodus
I suspect it will be more $ than the THX ones.
I'll probably go with the THX 788 as I'm guessing the Topping one will be in the $700 area. Thanks gvl and twsecrest!
gvl
SoCal
Maybe less with discounts, etc. My hunch is 500-600, but who knows.
Mocs123
I've never used a tube amp and don't know how one would measure but i see the Bottlehead Crack recommended often for the HD-600/650/6XX.
E
eXodus
Looking for an amp/dac combo, that seems to just be an AMP and one that's $500 alone :(
Mocs123
I thought the kit was more like $350 but I know there is some DIY involved. There are multiple $100 DACs that test well. You might could even build a Khadas Tone Board into the unit.
It’s just a thought anyways.
maverickronin
Midwest, USA
It's a fun build if you're looking to get into DIY electronics or if you already know you want a more colored OTL tube sound. Otherwise I'd give it a pass.
