Amplifier : how much power do you need
patate91
For those who are interested, here's a quick way to estimate your amplifier's power needs, based on your average SPL listening level :
1- You need the crest factor of your music track, usually between 10-20db :
http://www.richardbrice.net/leq.htm#:~:text=Symphonic, orchestral music can have,of only 8dB; see below.&text=It's interesting to note a,9dB greater than hip-hop.
2- Calculate the power needed :
10xLog(Amplifier's RMS) + 3 db. Then substract the track's crest factor.
https://www.prosoundweb.com/understanding-the-nuances-of-crest-factor/2/
and convert dbW to W :
https://www.rapidtables.com/electric/dBW.html
3- Use this caculator, with your speaker sensitivity to see what max SPL average level is allowed with your setup :
http://myhometheater.homestead.com/splcalculator.html
If there's something incorrect let me know.
*EDIT*
Or use this link :
https://www.kvalsvoll.com/Articles/AudioCalculatorspl.htm
pjug
I would use at at least 20db for crest factor. There are plenty of tracks with higher than this. I would use 25db to give a worst case estimate.
If your amp has some headroom above the continuous power rating, use the dynamic power spec.
I have little feel for peak SPL. Just speaking for myself. I think a listening method is better. Either using a scope or using the Pano method.
P
patate91
I agree : a 20 to 25 db crest factor will give a worst case scenario estimate.
P
patate91
Do you have some exemple of 20db crest factor songs??
pjug
I am traveling right now but not too long ago I used Rickie Lee Jones: Ghetto Of My Mind which has more than 20db crest factor.
Edit: sorry for the horrible thumb typing or autocorrect. Trying to clean it up. Also I think the 2L sample tracks are ballpark 20dB crest factor.
Kvalsvoll
Norway
There is ONE calculator on the net that can calculate this easy and correct and simple, it is on my web page, and if you find it, it is free to use, it does not require any registration or log-in, it does not collect ANY information about you as a user - it does not even log the data you enter.
So, why did you not use it? Because you never heard of it.
Sometimes, I really wonder what is the point in what I am doing. This is one of those times. No, it is not your fault, but seeing questions like this and knowing I have had the answer on my pages for years, makes me wonder if the world will ever evolve.
P
patate91
Just add the link here
Kvalsvoll
Norway
Oh no, you find it yourself. It is not exactly on the front page, but if you can't find it with reasonable effort, that can be part of the explanation.
On the blog-section there is an article about this subject "How much power..", a discussion around the subject, and how you can arrive at some useful answer.
TankTop
Click bait!!! You don’t even list your webpage.
P
patate91
Maybe Google is not referencing you very much. And if I don't know who you are it's pretty hard to find your profil. And add the fact that cellphone browsing sometime removes informations such as signature. Anyway I'm glad I've found your web site, this is usefull information and tool
frogmeat69
Western New York, USA
Kvalsvoll
Norway
Head_Unit
Good thread!
- Sensitivity is often exaggerated...OK, LIED about, the higher the more a lie, so be conservative.
- Amp power is fine but look at the 4 ohm power for 8 ohm speakers or 2 ohm power for 4 ohm. Because speakers are NOT resistors.
RayDunzl
Central Scrutinizer
Riverview FL
There's also this tool on the Crown Audio site.
Ok, let's try a Pro setup... for "peak" power
I wasn't so far off, maybe...
Crown: How Much Amplifier Power Do I Need?
"Although a rock concert in an arena could be powered by 15,000 watts (allowing only 6 dB of headroom for peaks,) you'll often see large touring sound companies using 80,000 to 400,000 watts total. That much power is needed to handle 20-to-24 dB peaks without any clipping, and to power extra speakers for even coverage of a large area."
https://www.crownaudio.com/how-much-amplifier-power#:~:text=Although a rock concert in,80,000 to 400,000 watts total.
Toslink
This tool gives you a very good look at why speaker sensitivity is important when it comes to amplifier power. That is, your power requirements go up quickly when running low-sensitivity speakers. The calculator, however, assumes a 6dB drop in SPL as distance doubles, equivalent to free space use. According to Harman's Todd Welti, who conducted a course in room acoustics I attended a few years back at the CEDIA trade show, the sound level drop off in "small rooms" was closer to 3dB for each doubling of distance due to wall reflections.
