Amplifier "sample test reviews" using Paul's Multitone Analyzer software
pma
pma
Prague
As @Sokel points out, the IMD calculation can be specified right on the definition of the test signal. Just add SMPTE to the end of the signal text.
I am specifically concerned of CCIF 19+20kHz IMD calculations.
REW shows this:
however Multitone Analyzer shows this (forget the X-axis shift of 3dB)
There is a huge difference in TD+N calculation
But, in case of 1kHz THD and THD+N level sweeps, both REW and MTA give almost same results:
pkane
North-East
REW shows this:
Hard to tell without knowing what settings were used. You may want to post the screen shot of the Spectrum settings panel in MT, as that has a number of values that can affect the computation.
pma
pma
Prague
I think not so hard.
All the spectrum components circled in red must be involved in the CCIF IMD calculations. And they are not, as one can see from the plot legend. Numbers in red rectangles are too optimistic, it seems that only difference tone F2-F1, 19.5-18.5=1kHz is taken into account. This is not enough.
It should be like this:
BTW, my MT setting is as installed default, V1.0.71
pkane
North-East
I'll check it out, thanks.
Sokel
The difference looks the same as between CCIF and DIN.
If it helps.
CCIF
DIN
pma
pma
Prague
pma
pma
Prague
SYM2 - my Single Ended (SE) to balanced converter with OPA627 and 2 x ADA4898-1
This thing is useful to convert single ended to balanced signal, it has high input impedance of JFET opamp and high output current capability of Analog Devices ADA4898 opamps. "N" is limited by my setup with Topping D10s DAC.
Comparison to REW THD and THD+N (SINAD)
(Stepped frequency measured at 3.6Vrms fundamental)
... and again same in REW
pma
pma
Prague
Measurements on NC252MP
The results are nice and predictable. Looking forward to X-axis cal option in [W] ;).
One more, DIN IMD vs. level :
Interesting.
pma
pma
Prague
This might be interesting as well - small signal, low power 250mW/4ohm/1kHz
and very high power 240W/4ohm at higher frequency 5kHz. Very good result.
@Sokel + the others, may I kindly ask you not to post videos in this thread, I would like to keep some technical value. Thank you very much.
@pkane : Paul, is the ENOB calculation correct? Please check these two images, thank you.
pma
pma
Prague
This plot shows THD and THD+N vs. frequency of NC252MP at very high power 240W/4ohm. Please note the loss of maximum clean power at lower frequencies below
some 800Hz.
DonH56
Monument, CO
some 800Hz.
Interesting, if vexing. Seems like this is a little worse than the previous 20 Hz sweep you did? Looks like distortion dominates given the THD and TD+N curves are very close. Any idea why the knee and rise below 1 kHz or so, then flatlining around 200 Hz? Is this using their SMPS for power?
pma
pma
Prague
I do not think it is worse now, because the previous plot was at 220W (below), and now it is at 240W. I assume the reason is SMPS, quite for sure. The supply voltage either drops or has high ripple or both. It is still within specs, because Hypex declares 250W/4ohm/1kHz/1%. The older measurement was made by a bit different method, true sweep, now in MTA it is done in stepped frequency, frequency measurement points highlighted.
The effect seen in the spectrum, above certain power/frequency point, is a sudden rise of noise floor (and distortion components as well, like in case of clipping).
DonH56
Monument, CO
Thanks! That leads to a whole host of other questions that just go deeper down the rabbit hole so I'll leave off. You'd think the higher feedback at lower frequencies would reduce the distortion, but if the supply ripple is going up and is correlated with the signal (or the voltage is just dropping and so it heads into clipping) then that makes a lot of sense. The roughly 200~800 Hz transition region is a bit curious, since it basically shelves before and after that, but maybe the ripple (or whatever) maxes out by a little over 200 Hz and then is somewhat constant below that. In the old days I'd double the supply decoupling (or maybe add a capacitive multiplier) and see if anything changes; harder to do with an SMPS, and less impact since the supply is regulated.
Good stuff, thanks for doing all of this!
pma
pma
Prague
Thank you Don. Let me show 2 less conventional plots, related to the phenomenon we are just discussing.
First one is Noise (relative) vs. power (into 4ohm) at 3 frequencies, 22Hz, 1kHz, 5kHz. Just noise.
Green link is for 22Hz and it shows reduced "clean power" at this frequency (elevated noise). Unfortunately the level step was 1dB, which is quite coarse.
The second plot shows H3 harmonics vs. power again at 3 same frequencies
As the effect is most pronounced in H3 (more than in H2), we may say that it is almost symmetrical clipping, related to PSU voltage drop.
DonH56
Monument, CO
Cause and effect is pretty clear from those, thanks Pavel! Jives with the earlier plots that imply it is mostly distortion, and I agree looks like supply drop at low frequencies.
