An analysis of some tracks, unprocessed, off of CD.
RayDunzl
Central Scrutinizer
Riverview FL
DonH56
Monument, CO
Also, if you're using a sine wave, you must use one that hits every level over your analysis window. If, for instance, you use FS/4, you will only get either 2 or 3 levels, depending on sin or cos, or 4 levels using something in between.
<elided>
This is exactly the issue the IEEE Standard (among many others) addresses.
DonH56
Monument, CO
Sorry I'm new here. It lists you as a technical expert, which sounds like you are by what you are saying. Who are you if you don't mind me asking?
Also, if anybody can explain in plain english what JJ is talking about, I would much appreciate it. What are missing codes? And how does a CD have incorrect loudness? Does this only happen when the sound is basically at clipping?
https://audiosciencereview.com/forum/index.php?members/j_j.493/#about
JJ is a legend and we are lucky to have him posting here.
That's a pretty impressive resume! I take it he also knows Amir because he worked at MS.
Yes, I hired JJ from Bell Labs as the chief audio architect in my team.
restorer-john
Is that because Jason Stoddard and Mike Moffat weren't available? :p
They were available, but Amir's budget couldn't stretch anywhere near enough to secure such luminaries. ;)
j_j
j_j
Audio Luminary
My kitchen or my listening room.
Missing codes are levels in the 16 bit integer that are not present in the data. Some missing near peaks are ok. Periodic missing codes are indicative of bad production, bad hardware, or thereabouts.
It's the CD Recording that is at fault when loudness or distortion are unpleasant. It's due to production. The CD process isn't the problem, it's the production techniques.
Everyone is welcome to the IEEE/AES talk at Digipen Oct 3 at 7:30 PM, barring some kind of disaster requiring cancellation of the talk.
Cosmik
But has anyone done any listening tests to see if music with missing codes actually sounds better? As long as the conclusions drawn were worded very carefully, that would be science... wouldn't it? :)
j_j
j_j
Audio Luminary
Bad quantization rarely sounds better. I could help you out by giving you lots of missing codes (4 bits no dither) and see if you liked it!
(snerk)
svart-hvitt
@j_j ,
is this a MIR project?
https://en.m.wikipedia.org/wiki/Music_information_retrieval
On the theme of loudness and dynamics I had great pleasure of reading these by Emmanuel Deruty et al. (http://emmanuelderuty.com/):
(1) http://emmanuelderuty.com/pages/publications/2015_DerutyPachet_ISMIR.pdf
(2) http://emmanuelderuty.com/pages/publications/2014_DerutyTardieu_JAES.pdf
The «genius» of Deruty was to simply see how a set of factors evolved over time. Would such an historical big data analysis be possible with your metrics as well?
