theywantmysoul
- Joined
- Jul 21, 2021
- Messages
- 31
- Likes
- 4
Hello everyone,
Planning to buy my first sets of speakers and need some help with it. Following are the details which might be helpful for you -
I guess my use case can be called as low - medium volume listening or Near - Mid Field listening.
I am inclined towards Dali Spektor 1. Sensitivity - 83.0 dB
Nominal Impedance - 6 ohms
Recommended Amplifier Power - 40 - 100 Watt
There was a similar post before asking for amp recommendations for Dali Spektor 1s but the budget was higher than mine.
Thank you for your time.
- My room - 2.6 m X 3.5 m. It's used as Living + Study + Bedroom
Windows - 1.7 m X 1.8 m high Curtains on two adjacent walls (curtains supposed to have soundproof quality to block outside noise, but can't say about it's effectiveness).
Floor - Rug 2.4 X 2.4 m, spend most of the time sitting here. (Speaker level?) Otherwise on desk - chair.
- Genre - Indie rock, Post rock, Shoegaze, Dream pop etc.
- Source - Windows Laptop and Android mobile. Plan to use Pi 4B.
- Dac - Discrete Dac absent. Might consider in future for use with headphones.
- Headphones - Absent. Plan to buy in near future - Meze 99 Neo/ Classic or DT 990 pro 250 ohm or Hifiman He400i (2020)?
- Speaker candidates -
Dali Spektor 1 ~ 230 USD
JBL A120 ~ 145 USD (86dB 6Ω)
JBL A130 ~ 190 USD (86dB 6Ω)
Wharfedale Diamond 220 ~ 275-525 USD
- Amps - Need small sized for desktop use.
Fosi Audio BT10A~ 55 USD
Fosi Audio BT20A ~ 62 USD
Aiyima A07 ~ 65 USD
S.M.S.L SA300 - 155 USD
STR-DH190 ~ 180 USD
LOXJIE A30 ~ 200 USD
Yamaha A-S301 ~ 245 USD
Cambridge Audio AXA25 ~ 245 USD
