Any comments on the MA700 Mono Amplifier
SirPaulGerman
I was offered a pair of MA700 Mono Amplifiers, I know they were designed for 5.1, thinking about using for a stereo set up.
There is not much info out there
Here are the specs
  • MA700-OM-EF_scan-Web.pdf
fpitas
Northern Virginia, USA
It being Marantz, you're probably OK if the price is right. I couldn't find much of substance, either.
fpitas
Are they specs any good ?
By the standards here, they're rather incomplete. But what is there should work fine, unless you have exceptionally golden ears.
sergeauckland
Suffolk UK
Or a very fertile imagination! :) Those specs, brief as they are, indicate an amplifier that's pretty unlikely to disappoint in normal use. The only issue I can think of is that there's no 4 ohm rating, only 8 ohms, so I would stick to 'speakers which present a sensible load.
S
fpitas
fpitas
Looks perfectly conventional for the time, nothing wrong there.
S
SirPaulGerman
Some pics of the amp
musicforcities
