Anyone else use rtings as part of researching headphones?
paulraphael
Brooklyn, NY
I used any and all data I could find including rtings, crinacle, oratory1990, diy audio heaven, r/headphones, and even head-fi.
Yeah, I think for headphones it's especially helpful to have many sources, because you see different looking measurements of the same thing.
I bought my headphones based partly on Rtings' review, and I love them. Amir got much worse results, and didn't recommend them. So who knows? In this case maybe I'm luck that rtings got to me first. I doubt there's this much ambiguity with other products.
3125b
Germany
I'm not a big fan of rtings rating system, display style and measurement visualization, I think it's pretty misleading for newcomers.
However the data itself is of course helpful, especially because they have a good number of main stream consumer product reviews, that other reviewers don't cover.
If I want to look up a random headphone, I usually go to AutoEq first. They have measurements of a huge number of headphones from different sites all in one place - however I think they should mark the sources of the individual measurements more clearly because they differ quite substantially in gear and compensation.
threni
/dev/null
I went there when I didn't know any better (we're talking reddit/head-fi levels of ignorance here). Having said that, I still think it has its uses. Like they say about newspapers: if you don't read them, you're uninformed; if you do, then you're misinformed. I don't understand their ratings, especially where you can slide a control around and make the numbers change but at least they're not just making stuff up randomly and I ended up buying a pair of HD 660S which are the best headphones I've ever used.
Sean Olive
Audio Luminary
There is definitely correlation between Rtings FR measurements and mine done on a GRAS 45-CA-10, so I frequently use this site to compare mine -There are some differences due to:
1. They use a Head Acoustics HMC. but they claim to have modified the Harman Target so its compatible with their manikin
2. They make measurements of AE/OE headphones on 4-8 employees which are averaged and spliced onto the HMC measurements below 500 Hz. These human measurements are intended to give more realistic leakage measurements as well as mechanical coupling to a human head. Most of these mechanical effects are between 80-200 Hz.
I have also started to compare our ANC measurements to their measurements.
I
D
devopsprodude
Beaverton, OR
The sliders are for filtering results based on preferences and don't change the ratings of particular headphones, IMO. It's nice to be able to say I only want headphones with a comfort rating of 6, bass 6, cost between $100 and $600, soundstage at least 7 and get a list of the few that meet the criteria.
D
Deleted member 27694
Guest
I like rtings very much and enjoy their content. But for me eg the AKG K371 (7,4) is a far more neutral sounding hp than the DT 770 (7,8) and the Etymotic ER4XR is a lot better for neutral sound than the 6,6 indicates.
D
devopsprodude
Beaverton, OR
Yep, their ratings definitely aren't perfect.
