Apollon Hypex NC2K Amplifier Teardown
Status
Not open for further replies.
This is a tear down of the recently reviewed Apollon NC2K monoblock amplifier. Both the owner and the company gave kind permission to do this.
As you all know, the heart of these amplifiers are power supply and amp modules provided by Hypex to its OEMs. There are some optional parts however such as the input buffer (amplifier), 12 volt trigger, etc. Beyond electronics, we also need to pay attention to quality of assembly as there are a number of DIY people getting into this business without the requisite knowledge of safety and proper signal routing. So let's start with our overall layout and shot of the amplifier:
One word came to mind when I opened this unit: wow! This is one clean assembly. The layout is clean. Everything is properly routed and super tidy. This is the best I have seen in these amplifiers.
Drilling in, the 2000 watt of power is generated by that tinny Hypex NC2K single channel amplifier. It is incredible how much efficiency in power and size we get in class D amplifiers. I did not look underneath but I am assuming the output power transistors are mounted to the chassis which I might add, is quite heavy and substantial for a class D amplifier.
Despite their high efficiency, you need a more powerful power supply to feed that amplifier to account for its own losses and that of the amplifier. This is provided by the Hypex SMPS 3K series switching power supply. As the name indicates, it is rated to produce 3000 watts. Consumption though seems to be around 3.8 Killowatts:
Apollon HYPEX NC2K BASED MONOBLOCK AMPLIFIER SMPS3K Capacitor AISHI teardown.jpg
While we are on this picture, the capacitors are made by Aishi which sounds Japanese but is the largest electrolytic capacitor company in China, producing 12 billion capacitors a year! Based on my quick look, their market is mostly light fixtures. The quality is apparently OK but I can't say I have run into them before.
The rest of the boards are provided by Apollon. While the black silk screen makes it impossible to see the traces and hence reverse engineer them :), they do look nice and serious. As noted in the review, this sample came with Sparkos discrete op-amp modules. I was impressed by the nice gold sockets they are mounted in:
Apollon HYPEX NC2K BASED MONOBLOCK AMPLIFIER Sparkos buffer board input teardown.jpg
As an aside, and as noted on the picture, all the cable tie downs are screwed to the chassis and not some double stick tape that comes off by the time you get the amplifier let alone longer time.
The next board is a linear regulator. It too seems to be using discrete modules rather than dirt cheap ICs:
Apollon HYPEX NC2K BASED MONOBLOCK AMPLIFIER Discrete linear regulator teardown.jpg
Can't read the brand name on the caps. Maybe one of you can identify them.
Electrical safety is paramount with a product with mains input and here, I was impressed with the best treatment for earth safety ground:
Nicely crimped green/yellow wire and screwed to a surface that doesn't have black anodization. This eliminates the need for sanding off underneath the cable which some manufacturers forget to do (or don't know that they should). This also helps with heatsinking of the power transistors.
And boy, are these hypex amp modules are made to travel given how they have glued everything and anything down:
Usually only heavy capacitors are glued down as they can literally pull themselves out of their PCB holes (seen and repaired some already).
The choice of amplifier capacitors from Hypex as usual is second or third tier:
I am always apprehensive when I open these Hypex based amplifiers worrying about amateur hour assembly. The exact opposite happened with the Apollon NC2K: this is a beautifully assembled amplifier matching and exceeding any requirement I have in such implementations. It is so clean you could take a picture of it and put it up on a wall as a poster! Very well done.
This strengthens my previous strong recommendation for Apollon NC2K amplifier.
Had a somber development earlier this morning. No amount of money is going to remedy that so not going to ask you for any donations with this review.
tomtoo
Germany
"... I did not look underneath but I am assuming the output power transistors are mounted to the chassis.."
At the hypex site you can see that the modules have two layers. The lower is a metallplate where the transistors are mounted. I mean at least it locks so.
So who's gonna sell this assembly with Nichicon caps ?
Nobody. You would need to place a large order with Hypex and spec the upgraded caps. I don't think it will happen.
Apollon Audio
The caps on our linear regulator board are Nichicon MUSE. :)
dfuller
Frustrating that an amp this expensive (and make no mistake, it is expensive by normal people standards) uses cheap Chinese electrolytics. But that's more on Hypex than Apollon. I wouldn't want caps that aren't Japanese or American/European in a switching power supply.
Matias
São Paulo, Brazil
And this is why my 2 amps are from Apollon. :)
ezra_s
Spain
want this.. have no money.. want this.. have no money...want this.. have no money.. want this.. have no money...want this.. have no money.. want this.. have no money...want this.. have no money.. want this.. have no money... :p
Archsam
London, UK
This is great, as it is difficult to distinguish all the different Class D power amps out there - most Hypex based amps are build using the same modules and power supplies, and priced very similarly. It often comes down to choosing the best looking casing / cheapest price.
Knowing how well Apollon build their amp definitely put them to the top of the list in my book.
Lorenzo74
Italy, Rome
If a customer prefers better caps we offer replacement/upgrade of the caps for Nichicon or Rubycon.
Does it worth? Do this increase the music enjoyment in a double blind test?
(Honest question, thanks in advance for your answer)
My Best
Lorenzo
stunta
Boston, MA
I have no need for this whatsoever and still want it.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
I know what you mean...
I wish I had some speakers and a space that could make use of something like that.
Like when I see a cool tractor, and I wish I had a farm.
Tks
Good job with pictures bossman! Gotten so much better over the years. Btw, what setup are you running? Camera/lens if you don't mind me asking?
Apollon Audio
My Best
Lorenzo
If I’m very honest with a cap upgrade the amp measures and sounds the same as with stock caps. The main difference is that the SAMHWA caps which are stock on most Hypex modules have a lifespan of around 5.000 hours and the Rubycon or Nichicon caps that we use have a lifespan of around 20.000 hours. The only caps that make a difference are the output caps on NC2K, NC500 and NC400 modules. Originally Hypex was using very good Polypropylene caps from WIMA on NC2K and NC400 modules. This is not the case anymore. Now they use far cheaper output caps. The only module that still has the very good output caps is the NC1200. I believe that because of the output caps that are used nowadays on the NC400 module for instance, it doesn’t measure as good anymore like it measured in the ASR review.
dfuller
My Best
Lorenzo
Any cap not in the signal path probably will have next-to-no impact if any on the output signal. It's more a reliability thing. Chinese caps are not known to stand up especially well under high ripple current (especially at higher frequency), high heat conditions... some American capacitors can be kinda janky too (ask any guitar amp tech about IC/Illinois electrolytics, we'll pretty much all say "they're bad").
Thanks. The camera is one of my older Canon 1Ds series (Mark III?). The lens is the Canon Macro 100mm F2.8L IS. Got that so that I could take shots handheld but then gave in and use a Gitzo tripod with ball head. Main lighting is a cheap but wonderful lightbox: https://www.amazon.com/gp/product/B07L9895XQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The whole thing sits on an electric adjustable office desk so I can move everything up and down to get the right shot.
Alas, I can't get to the top of it to take these teardown pictures from that vantage point. I place the unit on its side against the back and then use two more spotlights to illuminate the dark spots. Final stage is in photoshop where I reduce contrast as I find that my calibrated monitor shows far more detail in the shadows than typical uncalibrated monitor shows.
The camera is tethered to the PC over USB and has remote power so I don't have to mess with batteries, transferring pictures, etc.
It all takes a ton of space though and has made a mess of my work area but the results are worth it I think.
Status
