Apple Lightning to TOSLINK/SPDIF?
MKR
USA
Did a search (web and ASR) and can’t find any kit that provides for a way to convert/connect Apple Lightning (iPhone/iPad) cable to SPDIF/TOSLINK so I can connect digital bit stream (Apple lossless) to DAC input.
Anyone have a solution for this?
Thanks!
Dumdum
Nottinghamshire, UK
Apple USB 3.0 camera connection kit and an Smsl po100 pro I used this in my car for many years from an iPad mini 5 and iPhone XR
Now I use an iPad mini 6 with the AV adaptor to the same effect
Reactions: MKR
M
MKR
USA
voodooless
Netherlands
Thanks but nope … I found plenty of those. This has a DAC built in, which defeats the entire purpose. I don’t want it converted, I want the digital bitstream only to send to external DAC
Yeah, both of these give you exactly that.
Reactions: MKR
M
MKR
USA
I saw this, but this only converts lightning to USB. I need lightning to TOSLINK/SPDIF
M
MKR
USA
Ah, ok, yes. Seems the first one indeed does what I want. But IKKO has a built in DAC, and again I don’t want any conversion, pure digital bitstream only.
voodooless
Netherlands
They BOTH do what you want. The second one also has a DAC, but you don’t need to use it.
See the little (mini)Toslink LED?
Reactions: MKR
M
MKR
USA
Ok, I see. But how to disable the DAC? I assume connecting the TOSLINK means I get a digital bitstream, connect the 3.5mm jack is the analog output? Thanks for the help and sorry if I am asking stupid questions
voodooless
Netherlands
No need to disable it: put is a 3.5mm jack and you get analog audio, put in a mini Toslink and you get digital output.
staticV3
Apple USB 3.0 Camera connection kit converts Lightning to USB.
SMSL PO100 Pro converts USB to Toslink and Spdif.
Chain the two together and you get a Lightning to Toslink/Spdif converter.
M
MKR
USA
Excellent, thank you!
Dumdum
Nottinghamshire, UK
Ignore the rest of my post why don’t ya lol… the Smsl is a usb to toslink, i2s and coax digital converter
So you get digital audio from it however you want… it’s a very versatile combination
Reactions: MKR
Hov
The Douk Audio U2 may work for you. It is not a DAC, it converts USB to either Toslink or Coaxial. It has worked a treat for me up to 24/192 and I don't have anything beyond that to test.
Reactions: MKR
CauliflowerEars
I'm looking for the same way to connect iPhone (Lightning) -> (Optical/TOSLINK/SPDIF) DAC.
If I'm correct, all the above options are at least about 80 USD ...
Is there a cheaper way to connect the iPhone to the DAC?
I need it for my 2nd (cheap) setup. Either Loxjie a30 (DAC+Amp in one) or Aiyima a07 amp + Topping e30 II (Lite?) DAC.
The amps will get here next week to test and choose. For about 80 USD, I can get the Wiim Home and just stream directly ...
I've heard the Loxjie a30 USB input is worse than the optical. That's why I'm looking for a cheaper way to connect the iPhone ...
TY!
AdamG
Moderator
Reality
Hi DSM,
Have you had any personal experience with this particular interconnect ? If so in what configuration is the cable (Lighting to Optical, USB to Optical)?
Thanks for the link. Can’t say I have ever seen this before. The performance claims made by the Vendor are a bit snake oily don’t you think? Would love to see one sent to Amir for testing. ;)
