Are you a FAN boy? Fan-less vs. forced air music server / transport (passive vs. active cooling)
Is your music server / transport cooled with fans?
  • Active cooling - use fans (1 or more setups)
  • Passive cooling - NO fans (1 or more setups)
  • Both active and passive cooling (>1 setups)
Results are only viewable after voting.
Some pics from my huge audio server (cost around 30$, this is the 4Go Orange Pi Zero 3).
I wrote some code. When it starts there is some info about the current player:
For each new track in play mode, some technical info:
Then Artist and title, few seconds
Then the classic duration and X/Y
Size relative to the X16:
Ha yes, there is also some info for system monitoring.
RAM info, total, used and %used
Some info about the sd card:
And CPU load (and frequency for each core), right now the temp is not read (some new code to write for this new card):
Anyway the temp is around 48°.
And everything is containerized:
- lcd_monitor is some code for the lcd
- LMS is the open source audio server
- Squeezelite is the audio player
- portainer is the web tool for Docker management.
If I was not so lazy... I have to design a 3D box for this mega audio server. Consumption is less than 2W.
This might be of interest (first mini PC with solid state cooling):
Reminds me of the system status screen on a giant water filter system I maintained as part of my first company job. Some serious sentimentality being stirred by this one!
Once you quit being lazy and get around to that 3D box, I’m guessing you’ll go 200mm Noctua? A 140mm off-brand would probably handle it, but why not splurge on an already-absurdly-over budgeted piece of kit, eh? :p
Curious - how much storage does that server have to manage?
I’d heard mention of that tech but hadn’t looked up the computer. Neat - thanks.
Implementation of the power button looks questionable for a portable device; wonder how “portable” the power brick will be.
The chassis looks like an aesthetic match for this 2.5” drive RAID case:
Acasis 2.5” drive RAID case
Acasis 2.5” drive RAID case specs
There is a 4To disk to manage: 1.5To (a bit more) of music, the other files are for 3D models we build and some personal documents.
Since few weeks there is also a Orange Pi 5+ with nvme connector PCIe 3.0 x4 lanes etc... Not expansive, very powerful, I use one as my internet router (OpenWRT) and another one as workstation.
