Argon Audio
Dankeschon
What WiFi security does the solo support, i.e.,wpa-2 or wpa-3 ?
I had considerable difficulties with the airplay setup procedure (from my iPhone), and I suspect it because of lacking wpa-3 support (which my network requires).
Your thoughts?
I think we have Wpa-2 here works fine here. I prefer Airplay on iPad as it works best.
You can if you want download Google Home on iOS and use Chromecast.
I have one issue that on iPad the issue with chromecast is that Tidal often forget its connected to Tidal and then you must use Google Home app to control.. and it has no album art.
But this is either Google and Apples fault, not Solos
Dankeschon
Chromecast only seems to play Tidal in Cd quality That’s 16/44 isn’t it?
Jriver plays 24/192 over upnp.
Power Amp is chromecast so think it’s also 24/96
Please feel free to correct me if I’m wrong.
ads_cft222
Any news if tidal connect will be supported ? Is it a matter of licensing costs ? What is the difference in transmission type /quality when using mconnect to stream tidal compared to tidal connect ?
Jole
I'm the designer of the Argon Audio SOLO. Feel free to ask if you have any tech related questions.
-Michael
When you sending signal to Argon and have both output connected rca to AMP and coaxial to dac which one has advantage ( coax?) ....I will take off rca just I like to know rules how it works and test alone and with another dac
Dankeschon
Argon said its not going to do TIDAL Connect in near future, but maybe that Chromecast or AirPlay does better Hi Rez….
On my wishlist is TIDAL Connect.
ads_cft222
Upnp is probably the best transmission protocol followed by chromecast in absence of connect feature . Airplay does not do high res.
Dankeschon
I use Upnp with Jriver Laptop and Jremote and Sony Ubp X700.
I don't have Roon as it is so expensive..
Poweramp from my phone also Work 24/96 over Chromecast.
Chromecast also Work on iPad, but I prefer Airplay as it works best on Tidal. The limits of Airplay is 24/44
Airplay 2 16/44 says Argon Solos specs.
Chromecast Tidal is the same.
