only if it uses sonicap platinum's, i need my electrons to know how much I spent on their circuit pathsYes, of course...
How about a few tube connectors and a side of copper caps to go with that too?
But inordinately more expensive than free field testing for those that have it available, hence the existence of well measuring speakers made by small companies without either anechoic facilities or an NFSIt’s cheaper than maintaining an anechoic facility. Lol.
this is a fantastic idea! would be great to walk through the thinking behind the design process, choice of drivers, etc. i know it's all the the thread, but video's a fun medium too, and great to hear thoughts after the fact and next steps from here.This deserve a video. Maybe with Rick and Ctrl as guests?
I didn't say it's a problem, I didn't say we need to figure out to do it cheaper. it's a budget unlimited project, in other words , what is the best 2 way bookshelf we can make if there are no budget limits. There is nothing wrong with that, there is room for the uber expensive stuff, they make the SOTA advance.Not sure what the problem is here…ok 1.5k for parts instead of 1k. And sure finishing. So 2k maybe? Who cares It performs outstandingly well at any comparable price point at its firm factor. That was the goal as I read it. So job well done. Period.
No need to figure out how to do it cheaper. That’s a different speaker project. And I suspect one that would be extremely hard to do and significantly be better than the best sub 1k speakers out there.
Yes , this is a good tweeter to play 44,1 or 48 kHz sampling material. Not for 88 or 96 kHz . The resonance at 27 kHz will have distortion peaks at multiples of that frequency. That will cause a rise in the distortion profile at 13.5kHz for the second-order, 9kHz for the third-order and 5.4kHz for the fifth-order.DXT is known to have such break-up:
I wonder if it woudn't be bad to cutoff above 21-22kHz.www.audioexcite.com » SEAS H1499 27TBCD/GB-DXT
www.audioexcite.com
With material sampled up to 48 kHz there should be no problem. The highest level of information should then be at 24 kHz, not exiting the resonance at 27 kHz.Couldn't this be fixed with a RCL parallel to the tweeter?
@ctrl @Rick Sykora could you make a passive version as an MTM with another woofer in a bigger cabinet with a different tweeter for less than the cost of a Genelec? And could you change it from a PR to an MLTL?
Open source implies that once the design is finalized the design and specs will be available to anyone to reproduce. You don’t need all the measuring equipment to build the exact same speaker.I didn't say it's a problem, I didn't say we need to figure out to do it cheaper. it's a budget unlimited project, in other words , what is the best 2 way bookshelf we can make if there are no budget limits. There is nothing wrong with that, there is room for the uber expensive stuff, they make the SOTA advance.
Do you already own all the tools to do it? Do you have 4 channels of DSP And 4 channels of good amplification dedicated to it? ) I don't compute how you can evaluate the cost of an active speaker system without at least calculating that, and it's an extra 2K right there. You can, OK not think your time is worth any money, I can accept that, it's a great project and we can have hobby and learning activities.
What I'm saying is. If you don't have all that, The workshop, the time, the tools, the talent, the amps and the DSP, Nobody would deliver that to you under 5K, and that's if he is really nice. I am not talking "If it was to be a commercial project" Then it would be more, much more, just count the manufacturer, distributor, and dealers margin on top of that 5K. But Again I don't have anything against that.
Sure, but I didn't even mention measuring equipment. Someone still have to cut the MDF. It takes tools and it takes know how (and time that can be waived if it's for yourself) All the cost drivers are not development, they are mandatory to make the thing a complete working active system. Yes passive will be cheaper. But again, if we accept the premisse that it's a cost no object design, those crossover shouldn't be cheap to match this level of performance.Open source implies that once the design is finalized the design and specs will be available to anyone to reproduce. You don’t need all the measuring equipment to build the exact same speaker.
DIY implies one enjoys making them. A hobby, fun in which one trades time for price perhaps but that is only one aspect.
A passive version would make sense to offer. But beginning with it as active makes sense to me; especially as the dsp etc allows one to test different crossovers, filters etc. and trouble shoot bugs (even crowdsourcing those things on this forum) far easier than building a static crossover. it helps with the open part of the source in regards to the design process.
Eventually a specs for passive one could be offered Or even a few different options for a hardwired crossover.
And don't forget the DSP active crossover - this is a real game changer IMO... One imagines what the DIY designers of the world could do with low-cost drivers *and* the services of a Klippel....
I don’t understand…it’s either diy and open source or not. One either wants to and has the skills and equipment needed or not. I guess I am misunderstanding what you are trying to say. My apologies if so.Sure, but I didn't even mention measuring equipment. Someone still have to cut the MDF. It takes tools and it takes know how (and time that can be waived if it's for yourself) All the cost drivers are not development, they are mandatory to make the thing a complete working active system. Yes passive will be cheaper. But again, if we accept the premisse that it's a cost no object design, those crossover shouldn't be cheap to match this level of performance.
There is no reason to do so, since with normal music material the 27kHz frequency range is not addressed and even if it were, you will not be able to hear it.DXT is known to have such break-up:
www.audioexcite.com » SEAS H1499 27TBCD/GB-DXT I wonder if it woudn't be bad to cutoff above 21-22kHz.
You have chosen a somewhat unfortunate example. The Genelec 8330A also has a metal tweeter, which shows less HD2 at 96dB due to the breakup resonance (could be around 27kHz too, like the SeasDXT), but slightly higher HD3 compared to the SeasDXT.Here is a comparison with Genelec 8330 .
Just out of curiosity, if it is not cost no object, do you do you know any known designs of a 2 way bookshelf speaker pair, DIY or commercial, that would have a larger than 1.4K BOM cost before any active or passive electronics, before any woodworking? If this is not cost no objects, It would be pretty close no? I fail to see how you can get more expensive than that?A few quick points....
1. Am already working with potential suppliers of pre-cut cabinets. So expect no major power tools will be needed.
2. Directiva r1 was NOT cost-no-object. As stated earlier, the cost target was $1000. I missed a bit.
3. Passive may be cheaper, but cannot attain the same level of bass extension without eq.
