Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,237
- Likes
- 5,477
I'm guessing he's saying that 15 inch sounds more effortless than a 10 inchI legitimately don't know what this means.
That's what I'm talking about. I'm not a English native speaker, can't figure out how to express the feeling of the Chinese word '宽松感'. Thanks for translating more accurately.I'm guessing he's saying that 15 inch sounds more effortless than a 10 inch
I never had the opportunity to listen to the 1238A but own the RL901K. The big advantage of the Geithains is their cardiod design. It makes placement easy. A/B tested against the Neumann KH 310 and KH KH420 the Geithains sounded "more natural" to me. I also own the Genelec 8330A plus 7350A. Compared to the 901K they sound much "dryer".Today, I find another 16" Box called ME Geithain RL901k, same price as 1238A. Could this model sounds better than Genelec 1238A?
Ashamed to say, the funds are not in place yet.
Did you also audition the Genelec Ones?I never had the opportunity to listen to the 1238A but own the RL901K. The big advantage of the Geithains is their cardiod design. It makes placement easy. A/B tested against the Neumann KH 310 and KH KH420 the Geithains sounded "more natural" to me. I also own the Genelec 8330A plus 7350A. Compared to the 901K they sound much "dryer".
And they should play even lower with room gain.I do not know where you are located, but some dealers offer zero interest loan to get large ATCs. SCM50 and bigger are made to order, thus you will have to wait 3-5 months for delivery anyway. If you are OK with 30Hz LF limit, SCM100 (12") will get you there. SCM150 are for REALLY large rooms.
Or get the SCM300
Does the difference in shape and size make them sound different from each other?For living room (or should I call it ballroom) use this https://atc.audio/hi-fi/loudspeakers/tower-series/scm300aslt/ is better
I have had both and even at 90+ db I haven’t heard anything strained from either. Just that the KH420 have bass punch that the 15” lack.I'm guessing he's saying that 15 inch sounds more effortless than a 10 inch
Daren't touch DIYIf you like the effortless presentation of big woofers, you might find yourself a carpenter for cabinets, an electronics shop that solders you the crossover and get yourself a kit from these: http://www.troelsgravesen.dk/The-Loudspeaker-2.htm
It comes to the conclusion to me that RL901K is in the middle from ATC 150 PRO to Genelec 1238A, close to 1238A.I never had the opportunity to listen to the 1238A but own the RL901K. The big advantage of the Geithains is their cardiod design. It makes placement easy. A/B tested against the Neumann KH 310 and KH KH420 the Geithains sounded "more natural" to me. I also own the Genelec 8330A plus 7350A. Compared to the 901K they sound much "dryer".
I can actually spend some small money pre-ordering a pair of ATC150s, then wait maybe 4 months while the final payment is ready. BUT I want more details of the differences between these 3 models of speakers. Though in the end, I got to listen to these 3 models myself in case of wasting that huge amount of money.I do not know where you are located, but some dealers offer zero interest loan to get large ATCs. SCM50 and bigger are made to order, thus you will have to wait 3-5 months for delivery anyway. If you are OK with 30Hz LF limit, SCM100 (12") will get you there. SCM150 are for REALLY large rooms.
NO WAY, I'm not that rich and don't have a huge-enough space for the 300s. And I learned that there is no difference in sound between the Hi-Fi ver and Pro ver.Or get the SCM300
Yes, 1238DF + 7380 is an option worth considering.I think you're really too caught up in the 15" driver thing. It makes much, much more sense to go for a slightly smaller one and augment with subs if you want more bottom end response.
Room correction EQ is largely a fool's errand, though I know I will be shouted down on this forum for saying that.
actually this feels more like some kind of visual perceptiono more than the actual sound, for most rooms in China a pair of 10" would hardly need to work hard before friendly neighbours will come warmly discuss with you if possible I do suggest you to ask for blind testing on the short listed speakers and see if you can still identify the sound out. if you want to talk in chinese you are welcomed to pm and have some discussionThat's what I'm talking about. I'm not a English native speaker, can't figure out how to express the feeling of the Chinese word '宽松感'. Thanks for translating more accurately.
Heard ATC is loosing customers with these, crushed rib cages caused by infrasonics is the word on the streets.For living room (or should I call it ballroom) use this https://atc.audio/hi-fi/loudspeakers/tower-series/scm300aslt/ is better
