Count Arthur
- Joined
- Jan 10, 2020
- Messages
- 2,254
- Likes
- 5,060
No because the ATCs off-axis is so ragged in comparison.
Who spends £15,000 on a pair of speakers and sits off-axis? There's Sonos for that sort of thing.
Did you know thousands of studio are using ATC?
So... ever heard of the NS-10 or Auratone 5C? They're both the polar opposite of "flat" and "neutral" but we use them specifically because they're more like common, relatively low fidelity playback systems. One of the hardest lessons to learn in audio engineering is that the big fancy mains lie to you. They're great speakers, which almost invariably means that mixes don't translate.If not to mix/master using as neutral as possible a monitor with sufficient bass extension, power handling etc. etc., what would these priorities be? Or alternatively, which priorities would lead an engineer to choose an ATC over a more neutral option of equivalent size/cost?
So anyone has measurements of ATC's most popular model SCM 110a? OR every measurements of big boys for mastering purpose? NOBODY
You think speaker design is a dice roll?.
Well what’s the consensus?
I think good, but not SOTA, not when comparing with what’s currently available.
I apologize. There are so many trolls out nowadays that questions can take on an antagonistic appearance. I hope no harm was done.
I've never met engineers from the big studios. Because I was an amateur, I met only people in small, local outfits. A few were some of the most idiosyncratic, bullheaded people I ever knew. One refused to use anything that wasn't highly directional. That wasn't odd; there was no consideration of "room response". A certain axis relative to the speaker was chosen because it translated well for that particular engineer, and that was that. Another one wanted elevated treble response. He said it provided "clarity" in catching editing artifacts. That, also, was a somewhat common attitude. But another (not in the same studio) wanted a reduced treble. All of these rooms were treated and fairly dead, because that made differences easier to pick out.
Once, I heard that a certain engineer won a Grammy using Event monitors ..... I can't remember for sure, but it might have been the 20/20 BAS model. I mentioned this to one of the guys in the studio, and the reaction was immediate and unprintable.
And then there were people who put absolute reliability as their highest priority. I once heard one say, "You can learn to mix on any speaker except the one that's not working."
Some of the people I knew put autosound as the highest priority. Why? Sales, of course. Those people mixed magic fairy dust. Mixing for high-compression autosound was NOT easy.
But now I'm old, and I'm half deaf. Take what I tell you whichever way you please. Despite my previous comments, I won't be offended by legitimate disagreements. I'm sorry if I gave that impression. Have a nice day. Jim
Am I right in thinking that the D&D have DSP built in, so you're comparing the D&D "corrected" to the ATC "raw". Presumably, with some DSP, you could adjust the ATCs to measure similarly.
Some thoughts.
1. Is it possible that the less "accurate" of two speakers might sound better in a particular room, because the peaks, or dips in it's frequency respones just happen to work in synergy with the rooms acoustics?
2. Could it be that the innaccuracy of a speaker happens to coinside with a sound signature you like. Perhaps an emphasis in the mid bass which adds a bit of punch which you find pleasing, or some extra energy on the upper mids that gives the impression of greater clarity.
3. With nothing to compare it to, the ear/brain gets used to a particular sound and after a while it sounds OK and it sounds right. I think sometimes, if you switch speakers, or heaphones, you can very easily hear that they sound different, but sometimes you'd be hard pressed to say which actually sounds better, or more accurate.
I went into an audition of ATC speakers in early 2018 wanting to like them, just because of the studio use and reputation. I only heard passives, because there are no audio showrooms in the NY area that will show you the actives (And lots of salesman who will lie to you and tell you what a terrible idea actives are).
Anyway, I wasn’t all that impressed. scm40s, as I recall. I liked the Wilson Sabrina’s better, side-by-side. But then I liked the Harbeth SHL5+ better than both of them.
Btw, I did go to the Harmon showroom. The salesperson absolutely stunk of cigarettes, played some JBLs for me and lost interest. So I never heard the Revels.
Storefront Audio retail is such a disaster.
Although I haven't checked... I'm guessing with the advent of distributed, cloud-based solutions which require flexibility and scalability of deployment above all else - those companies are all out of business now. Either that or they eventually had to change themselves, rather than expecting the client to do so.
Most people do prefer "warm" and "musical" sound, and i can't blame them, it's easier to listen to, i like accurate and flat and uncolored sound (Genelec for example)I think your post gets to the heart of the matter. None of the speakers you listened to that day are what most here would admire.
This is the Wilson:
https://www.stereophile.com/content/wilson-audio-specialties-sabrina-loudspeaker-measurements
The Harbeth is better:
But objectively not that great compared to far cheaper and far better measuring speakers like the KEF R3.
Yet many swear by those you enjoyed and others that are even more objectively amiss such as all recent B&W speakers, consumer PMC speakers and many many more.
If 'accuracy' did indeed translate into preference we'd all be listening to Revel, KEF, Genelec and the usual suspects.
And we wouldn't be adding a 'target curve' for the sake of preference over reference.
Judging by sales, most people prefer inaccurate.
