Audio Interface / DAC needed for Adam a7x?
krychu
Hello everyone!
I'm waiting for a pair of powered speakers (Adam a7x) to arrive and wanted to ask for some advice. I'll be using the monitors to listen to the music from laptop/computer, no music production, no recording etc. I currently have Magni 3 and Audio Technica r70x headphones. I could just plug the monitors directly to Magni with RCA cables (Magni acting as a preamp). Would that be a bad option? Or should I get Audio Interface or DAC, just wondering if the difference would be very noticeable?
If getting Audio Interface / DAC is recommended, what would you recommend circa $100? And should I connect it to Magni or keep both separate?
I'm not too experienced with the subject so appreciate all the advice, thanks so much in advance.
K
krychu
just to add more detail, I don't need any inputs for mic or other devices, just a good setup to listen to music from computer, without sacrificing quality by not getting $100 audio interface or some other piece of equipment. I'm just realizing that what I might be needing is just an usb soundcard or audio adapter (?)
Zensō
California
Hello everyone!
The Magni should work fine as a preamp with your Adam monitors. For a DAC, the Modi would make a nice stack with your Magni. So, PC>Modi>Magni>Adam A7X
K
krychu
Thanks a lot, I was looking at modi but a bit worried that the whole setup would basically be unbalanced. Interesting about line isolator, haven't considered that so far.
K
krychu
Ended up getting Scarlett 2i4. I'll drive adams directly from it with balanced TRS->XLR, and then also connect Scarlett with Magni with unbalanced cables, and drive headphones from Magni.
