Audio Interface for REW and Laptop
SimpleTheater
Woodstock, NY
I'm hoping to use REW to test my stereo and other non-HDMI audio systems.
It doesn't appear I can do this with just a UMIK1 and a laptop as I did with my Home Theater AVR using the HDMI connection. Since my stereo gear is either rca or balanced inputs, I believe (I could be wrong) I need some type of audio interface.
Recommendations under $300 would be appreciated. I'm not in need of professional quality as I'm most interested in doing RT60 measurements.
GDK
Toronto
Can you not connect your laptop to your DAC via USB? That's how I have normally done it.
SimpleTheater
SimpleTheater
Woodstock, NY
I have an RME ADI2 DAC. It has a USB input.
Should I use standard USB cable or get a USB-C to USB cable (my laptop has both USB-C and regular USB).
GDK
Toronto
So that is exactly the same as my setup. Yes, just use a USB-C to USB-B cable to connect your laptop to the RME and REW should work fine. No need for another interface.
rdenney
My measurement microphone has a standard microphone balanced analog input, and I needed an interface with a mic preamp and phantom power to run it. I use a cheap Presonus Studio 24C. One advantage of REW is that you can do a loop back test of the interface and make a calibration file for it. Mine was within a fraction of a dB across the spectrum.
Rick “whose Benchmark ADC had insufficient gain for microphone levels and no phantom power” Denney
SimpleTheater
SimpleTheater
Woodstock, NY
I know it doesn't seem like much, but that is so awesome. It took me forever to hook up REW with my AVR, I just assumed it would be just as big of a hassle for something else. But I just plugged the RME into my laptop, set it as the default output, and everything worked perfectly. Just took a quick measurement.
Thanks a lot!
