Audiofools turned objectivists or vice-versa?
gsp1971
Europe
Anyway, to get back to the topic of the thread, there are a few examples of subjectivists who turned objectivists, but I wonder are there people who went the opposite way?
ahofer
New York City
One of the Stereophile guys said he did for a while, but he was miserable so he shifted back. I don’t remember if it was Atkinson, who is here on ASR from time to time. Or maybe Holt.
DimitryZ
Waltham, MA, USA
By whom, and using which test format?
I think I will be the subject and AB format. 10 trials?
I think on IOS, nonplaying DAC has to be physically off. I will need to fashion an opaque shield that will hide the DAC from view.
I will also need to show my wife how to turn the DACs on and off and how to use the switch box.
SIY
Alfred, NY
A lot of potential non-auditory cueing. I’d look at a sorting format. Sufficient trials to get you to better than 5%.
Before getting fancy, do a level matched comparison. You may be surprised.
DimitryZ
Waltham, MA, USA
What is a sorting format?
And it turns out that my Liberty and M2TECH output 5v from their balanced analog outs.
SIY
Alfred, NY
That is not sufficient to determine level matching. You have to measure the outputs with identical signals and match to 0.1dB.
DimitryZ
Waltham, MA, USA
I only have a digital voltmeter. That's probably not enough - I will need to clearly distinguish 5 vs. 5.06 volts.
I do have one of those calibrated microphones that plug into your phone and work with audio apps. But I don't think it's dependable to 0.1 dB.
It sounds like I need to get a measuring interface for PC and some software?
SIY
Alfred, NY
I only have a digital voltmeter. That's probably not enough.
Voltmeter will likely work fine.
Wes
pink noise may be better
rdenney
Pink noise isn't centered--it covers the entire audio spectrum. But it is random noise, so the reading may wiggle a bit.
But 1KHz will also work fine, and it will not likely explore the bandwidth of the AC-reading part of your DVM.
It's not important that the reading is really accurate, but rather that it's repeatable so that matching the devices under test will really match them.
If you use a DVM make sure it is a true RMS-reading meter. Most better ones are if they claim to be. Most can read power properly, but the meter needs the bandwidth to read 1000 Hz, not 60 Hz.
Rick "who uses an old Trio SSVM for this task" Denney
DimitryZ
Waltham, MA, USA
I need to locate my test CD, I think it has pink noise and 1/3 octave white noise, if memory serves.
In the old days I used it to manually measure my Magnepans with RS meter, which was really bad and one had to use corrections table...
audio2design
I don't think this is true at all. Since at least the 1970s, any mass-market receiver, run below clipping, has been sonically indistinguishable from the most expensive amp/pre-amp combinations that were properly designed for flat frequency response and low distortion (which includes almost all solid-state products and many tube products). And DACs in CD players have been sonically perfect since the very first Philips player (which I owned).
That is not totally true. Many of those older receiver / amps had rising often significant distortion at high frequencies. You will note it is rare to find specs from that age with distortion measured anywhere but at low frequencies.
Blaspheme
It was JA, he includes that story in a column Who Watches the Watchers? The overall subject matter is relevant here.
SIY
Alfred, NY
A sine wave will be fine given that DACs are all pretty flat except in the top octave. 200-1000 Hz will work great.
MarkS
How old is "older"?
From the February 1975 issue of Stereo Review, page 32:
“Sherwood’s next-to-lowest-price stereo receiver, the Model S-7110 … can deliver 17 watts per channel into 8-ohm loads at less than 0.9 per cent harmonic distortion between 40 and 20,000 Hz.”
https://worldradiohistory.com/Archi...iFI-Stereo/70s/HiFi-Stereo-Review-1975-02.pdf
gsp1971
Europe
I find it quite strange that a technical editor in charge of measurements does not advocate a pro-measurement approach to component evaluation.
I am sure JA knows better than that, he has been in the business for way too long and he has massive technical knowledge, but he needs to balance component reviews with advertising revenues, hence the more cautious approach.
