somebodyelse
- Joined
- Dec 5, 2018
- Messages
- 3,790
- Likes
- 3,102
I guess it depends on what you mean by 'standard Ethernet' - it's using things standardised under 803.1 and 803.3 just like the switches you deal with. If you're dealing with enterprise level switches there's a good chance they implement most or all of the necessary extensions, but most cheaper switches don't. I suspect this has more to do with market segmentation and that most users needing to deal with precision time also have deep pockets, and less to do with the actual cost of implementation. Think telecoms companies, high frequency traders and big industrial sites. The switches from the likes of MOTU use relatively cheap silicon that may be in something much cheaper that doesn't advertise the capability.Funny you mention this. We recently decommissioned some switches and looked randomly at their logs on the syslog server ... Not one dropped packet, in a quarter (3 months) on several dozen of GbE interfaces. Not one... Said interfaces had multimedia on them ...
Seriously would like to know what this AVB brings that standard Ethernet doesn't ...
A "solution" in search of a problem?
Peace.
The 'problem' is being able to guarantee bandwidth and low latency between source and endpoint, not just have it be good enough almost all of the time. It turns out it's not only a problem in certain (mostly large) AV situations. Real-time industrial control applications have a similar problem, hence the change of name from AVB to TSN (Time Sensitive Networking). If "good enough almost all of the time" is sufficient you can use Dante, AES67 etc. with commodity network switches. That probably applies to most professional situations, let alone hifi applications. Most of those protocols are using most of the same standards underneath anyway, just with slight differences in how they use them.
