That's exactly what I say from the beginning,maybe my poor English don't help.That's not an example of what you just said.
But as we know from the many tests done here. Good dacs don't care about clean power - even if they are powered from the USB port. They filter it internally.That's exactly what I say from the beginning,maybe my poor English don't help.
But I separed it early saying that I'm not talking about the intergrated audio every motherboard has.
Edit: here:
"Audiophile" motherboards
I'm talking about the ones who advertise "audiophile" grade constructions,with separate USB paths,etc. Truth or snake oil?And do we have any measurements?www.audiosciencereview.com
Yes.but there is not a week passing without a thread about fan noises,cpu noise activity,ground loops,etc.But as we know from the many tests done here. Good dacs don't care about clean power - even if they are powered from the USB port. They filter it internally.
So in that case, this just becomes more audiophile nonsense.
Marginal power filtering seems to be a common theme in dongle DACs.Good dacs don't care about clean power - even if they are powered from the USB port. They filter it internally.
Forgot to mention that Khadas here is powered by a Salas PSU,only the ground is connected to the PC,on the other hand E-MU is PC powered.If it's not passing all the weird fan/cpu-gpu activity is good enough for me,in the past I had a rig who I could hear everything!
But even with my present PC which is silent in terms of what I here I have funny things to show:
That's a sloppy measurement of the Khadas tone1.
See the grass?
Now,If I change the polarity of the PC's wall socket (in some countries in Europe you can do that,line-neutral-earth have a code but is not always following it,so...) the grass on the left approaches the 100's region instead of the 120's you see here.
Not to mention than even the placement of the measured devices count but that is something else.
Ok,since I do not hear it I shouldn't care.
But is the principle.
We'd need to know the reason for the SNR reduction, before that can be evidence of benefit for audiophile motherboard. To start with, the performance is already near 20db worse than measured by Amir - so what else in the system is generating noise? EG ground loop, which MB design is unlikely to help with.
Amir's test rig is designed to extract the very best (or worst) without contributing anything by itself.near 20db worse than measured by Amir
They don't ask for a premium as I have seen,it's more of a feature,at least in Gigabyte's case,I just wonder if it really works,that's why I'm asking for measurements.@Sokel we sean how it can effect designs with industry leading EMI rejection rates for a CS43131 DAC in case of dirty power supply and how it's impossible task to get rid of it with OP Amp's that ware not very good at it. All of that with external (multilayer) CPB's in enclosures. The PC case it self is a horrible environment with switching power supply on the high load, bunch of high consumers, magnetic dust filters, bunch of RF radio transmitters. I don't say it can't be done (actually believe it can with Polimer Termo Graphite Elastines as a shielding which they still don't use) but why and at what price? I mean you have a great external DAC's for little more than 100$ and if you use optical link you can be totally assured it won't effect it at all.
No, it is between a PSU and a laptop. We've no idea if the difference is from the power supply to the Dac - or something else related to the system, such as how grounding changes - or even position of wiring.Amir's test rig is designed to extract the very best (or worst) without contributing anything by itself.
Not the case with real life performance.
But the above example is between two PSU's and the difference is huge.
My own results is also absolutely repeatable between external powered Khadas and not.
What does this buy you vs an outboard USB ground loop isolator?A number of years ago, AOpen produced a motherboard equipped with Sovtek 6922 vacuum tube and other audiophile-type parts, and I wanted one for the sheer improbability of it all.
http://ixbtlabs.com/articles2/aopentube/
Gigabyte USB DAC-UP sounds like a ground-loop eliminator built into the motherboard. If you actually have a ground loop via USB connection, I'd expect it to make a very noticeable improvement.
Agreed,but in my case the only thing different is the powering,in one case throught PC in the other with Salas.No, it is between a PSU and a laptop. We've no idea if the difference is from the power supply to the Dac - or something else related to the system, such as how grounding changes.
USB Isolators start at $5. Outboard isolators are portable and that way you are free to choose the motherboard for the other features you want or on price.30-400 euro (depends what isolator you choose) in your pocket if it works?Motherboards feature is practically free.
I'd just go for a mothboard with built in Toslink. Complete electrical isolation of PC from Audio. It doesn't get better than that.30-400 euro (depends what isolator you choose) in your pocket if it works?Motherboards feature is practically free.
