nemesis.ie
- Joined
- May 30, 2022
- Messages
- 101
- Likes
- 57
But that means, the gain would be 12,8 dB... ideal would be 26dB?
Ideal depends on your situation/input. For my system 12.8 dB gain is ideal - anything higher and I get tweeter hiss. Lower gain givea better SNR/SINAD per Amir's revirew, but if you have low sensitivity speakers and a low input level, the higher gains may be "ideal" for that case.
@Vhond The only apparent difference is the case and the jumpers are now accessible from underneath and have "finger tags" on them so easy to move.
They also have an LED defeat jumper but not (annoyingly) on the mono block model. See earlier posts.
