Audioquest Dragonfly Black v1.5 review
Dilettante
Measured as following:
USB2 port --> Dragonfly Black v1.5 --> 3.5-to-TRS adapter --> ID4 mk. II
Software gain was set to 100% via Windows volume control. Do note the ID4 impedances: 2.8 KOhm for the mic and >8 KOhm for the line inputs.
Whenever you see "preamp on", it means that microphone preamplifier was activated and its knob set to ~10:30. This gives us +8.4 dBFS.
1 kHz sine
Line inputPreamp on
Sweep
I have repeated these measurements several times. The curves look almost identical indeed.
Line inputPreamp on
Multitone 32
Line inputPreamp on
RMAA measurements were consistently failing. Even with the ID4 preamp set to maximum, the output level of Dragonfly were insufficient:
Well, unsurprisingly so.
pkane
North-East
1 kHz sine
Sweep
Multitone 32
Try some averages with Multitone measurements. Say, 16 or 32 averages, 87.5% overlap, Amplitude or Hybrid. This will help bring out some more details in the noise, while shrinking the noise band to make the display cleaner. In the new version of Multitone, this will not take much longer to do this.
Chrispy
PNW
If one provides any revenue to the charlatans at fraudioquest you're just shooting yourself in the foot so to speak....
Dilettante
Dilettante
I wouldn't be sad if Audioquest are charged with fraud for what they do with their cables, etc.
However, let's stick to the facts. This product, while not a benchmark, delivers better audio than many of the in-built ALC***, can be used via USB OTG and has enough of power to drive headphones typically used with such plugs. In other words - it's not a scam.
Chrispy
PNW
LOL of course I couldn't agree to that. I've not seen/experienced any fraudioquest product that actually did something better than something suited to the purpose.
Dilettante
Dilettante
@Chrispy , I am here not to defend Audioquest or make their products sound better than they are. However, at minimum, please make an effort to use the correct spelling and rely on facts (e.g. numbers) rather than emotions. Otherwise, your "something better than something suited" sounds like a vague bigotry.
Chrispy
PNW
Did I not say fraudioquest? Fuck Bill Low.
mansr
Hampshire
Then again, a $9 Apple dongle gives you better performance still. How overpriced does something need to be before it becomes a scam?
Chrispy
PNW
It ain't called Fraudioquest on the side for no reason....
Chrispy
PNW
Fraudioquest is excellent at overpriced pretty much everything....good marketing, good for audio not so much.
