AudioQuest NRG-X3 Review (AC Power Cord)
Rate this product:
  • 1. Waste of money
    Votes: 324 89.0%
    Votes: 29 8.0%
    Votes: 4 1.1%
    Votes: 7 1.9%
Spkrdctr
I wish some publication/site would get maybe five or six people in a room that have very educated ears and do real blind tests. That's where the rubber meets the road I think. With a very high end setup, test 14 gauge Home Depot wire against $30,000 interconnects. Test a new and frankly incredible $2,000 D-class amps against some 125 lb. A-Class mono blocks. Tube vs. solid state. I really appreciate the work Amir has done to find out what is real, I think another site that just did blind tests would be the whole enchilada. I grew up on those 80's stereo rags and looking back they were mostly full of it, trying not to fall out with advertisers; they basically said everything was great. Everything was not great.
Well the problem is that everyone hears a little differently and what a bunch of "educated listeners" may prefer will not be what the general public likes. Also, the wire, interconnects and amps testing has been done and people who claim they can EASILY hear differences in equipment can't hear any differences when the blindfolds are on. A mid price Denon or Yamaha AVR, a mega buck Class D amp or big Monoblock's all sound the same when blindfolded. The reason is that as Amir has shown many, many times, the difference between any of this stuff is measurable and it is so small that it is not audible to the listener. The speakers are the extreme weak link in the testing system. For example and I'm making this number up to show the concept. If you have a 1 millivolt difference between two items in the signal going to the speakers, the speakers will not sound any different as 1 millivolt is way below the speakers ability to resolve at that level. The speakers are like the big brute in the chain and overwhelm pretty much everything else. This has been known for decades yet snake oil marketing is what is used for most audio products. This so far is settled science. On ASR the measurements are usually (but not always) not audible. Amir does test product and then we see if it is junk, mediocre or great. ASR if full of good info.
F
freemansteve
Guest
Of course the tested cable makes the sound more musical - without a cable there would be no sound. There would also be zero distortion and zero noise. :)
xaviescacs
La Garriga, Barcelona
I've contacted the company, asking for more information about this test. They say from 2 to 5 days to answer.
We'll see...
Well, after more than 10 days, QED people haven't answered yet my request of information about what "typical amplifier" have they used to obtain the results presented on this paper. It will remain a mystery...
ESLDude
Audio Sales guy asks me - "How are your cables working for you? I reply well I turn on my source, my amplifiers and those electrons just find their way to my speakers and I have great sound. Audio sales guy says "what do you mean?" Audio sales guy next to him smiles and says "I think he just told you" LOL
Awsmone
This is a review and detailed measurements of the AudioQuest NRG-X3 AC power cord. I purchased it a couple of years ago for testing and costs US $99.95.
The cord is 16 gauge and is more flexible than my thicker freebie AC power cords. The mating ends connect perhaps a bit more solidly than my generic code. I think the terminals look ugly but they work.
There is no mention of any regulatory certification, UL or CE, on either the cord, box or the website. My generic AC cord has UL stamped at one end and the cord itself. It also has more specifications as far as insulation type, temperature rating, etc. which the Audioquest lacks. I am curious how they export it to EU without CE certification.
I was "delighted" to read the feature list of the NRG-X3:
We know how to measure both distortion and noise. And company clearly cares about both factors.
My sample is 2 meter and the generic one is what I have on hand at same length.
AudioQuest NRG-X3 Measurements
I started by measuring the DC resistance of both cables. My generic cable came in at 0.13 ohm whereas the AudioQuest was better at 0.02 ohm.
Next I decided to measure the distortion in both cables. To do that, I terminated the cables into IEC sockets at both ends and ran them into the differential outlets of my Audio Precision analyzer. Let's start with measuring the Audio Precision itself without any cable with 20 volts output:
As you see, I used 60 Hz as the tone to mimic mains frequency. Despite the high output voltage, performance is superb with distortion below -140 dB and SINAD at 120 dB. Now let's measure the generic AC cable (treated as a signal cable):
There was some variability and slight rise in distortion at 180 Hz. Considering that we are treating an AC cord as a signal cable, this is extremely good result showing that there is little distortion to worry about in a power cable. In a pinch, this generic AC cable is as good as a balanced cable!
Let's now switch to AQ NRG-X3:
The harmonics were dancing up and down. Within that variability, I think we can call this a tie. There is no reduction in distortion using the AQ cable.
Someone may say that one cable is better than the other in high frequencies so let's expand the bandwidth to 1.2 MHz and see if there is a difference there:
Nope. They are the same.
I then ran a reverse leakage test. I brought a transformer near both cables in the above setup and captured its AC noise and distortion (changed the drive frequency to 1 kHz to make that easier to see):
We see that both have similar susceptibility to magnetic induction. This is an extreme test though. Move the transformer an inch and all the interference disappears from both cables.
As usual I like to remind everyone that we don't listen to AC cords directly. We listen to output of our audio gear instead. So let's grab the last DAC I tested, the Topping DX5 and let's see if the performance varies between AC cords:
It doesn't get more identical than this.
Let's switch devices and use the AC cables to power an amplifier, the recently tested Audiphonics HPA-S400ET:
Again, you couldn't get more identical results. The two graphs have landed on top of each other perfectly.
Company advertising for NRG-X3 is very specific with respect to reduction of noise and distortion. No matter if we test the cable directly or through a piece of audio gear, there is no detectable difference despite the incredibly precise nature of our measurements. This makes statements like this from the review of said cable by Stereophile quite dubious:
"The AudioQuest NRG-X3 delivered more music, made more sense of the music, managed to more fully convey the artists' intentions, and made me a happy guy."
Making more sense of music? Fully convey artists' intentions? Good grief.
Lack of safety standards is a concern. We don't know the abrasion resistance, temperature rating, etc. either. So better not run over the cable or place it next to hot items.
On the positive front, the cable does seem to have lower DC resistance and is flexible. And at $99 price I paid, it is not hugely expensive. So if you bought one, I am not going to chase you. Personally I have better use for my money than spending it on power cord so can't recommend the AudioQuest NRG-X3.
Edit:
video review posted as well:
Can I ask a technical question, at what level of inductance in a power cable would it effect the current draw of a power amplifier so
if in a class ab design there is a sudden Increase in the power required to be delivered would the power cable inductance have a negative impact in real life, I note it can in very high power settings eg lasers requiring >200 amperes
TheBatsEar
Germany
I would say it shouldn't be thinner than that (we are looking at 4 layers of 0.6mm wire, about 6 meters):
I wouldn't recommend sending >200 amps either :cool:
I don't think there is a meaningful answer to your question.
egellings
Since power cords have 2 current-carrying wires in close proximity to each other and the current will always be flowing in opposite directions in them, the conductors may well be magnetically well-coupled enough so that the inductance would be minimized. And, at 50/60Hz, who cares about a small amount of residual inductance in a power cord anyway? There are other more pressing problems to solve.
Awsmone
Thank u that was my understanding, just wanted someone more competent than me to confirm :)
Mihalis
Because plenty of people who buy them don't!
That is exactly right. Being an audiophile and musicophile myself I can assure you that it is quite a task for a non technical person to get out of the fog of bs that the industry peddles. behavioural psychologists explain very well why this happens and it is truly disappointing that there exist no standards that would trip up an industry that is to a large extent based on complete nonsense. The more of these tests that can be done, and with much much more expensive equipment (one and two zeros more) it would be helpful, interesting and may provide some guidance to whomever is open to listening.
BadOlePuddyTat
I like a little bling in my audio system, so I wouldn't mind paying $100 for a power cord. It would have to be nicer looking than this one, though. Maybe if it came in different colors, I'd pay $45 for it.
Marmus
I have a personal conflict there. I know the founder of Shunyata. Been to their local factory and they were super nice and kind to me. They also do fair bit of objective analysis and own an Audio Precision analyzer like mine.
Of course if someone sends me their products then I will fairly review it. But I prefer to not go and buy their products to test.
Amir. You should have any who may post here read Kahnaman's thinking fast/slow. Actually a simple read. Using those measurement methods he earned a Nobel in (economic) decision making. Also should read Diana Vaugn's version of Challenger disaster,a socialization problem (of course other things too) Neither economics nor rocket deaths used data. Same for politics and obviously most of the public buying stuff.
Descartes
Unfortunately so many cable manufacturers are crooks and so are the dealers that sell their crap!
Many people get ripped off by the marketing and unscrupulous sales practices! If only this was regulated and they were forced to release data!
Flak
Industry Insider
Great Panther/piggy-bank image :)
egellings
Still have my bamboo Versalog schlip schtick and the HP-35 calculator that replaced it. Both are in working order.
Spkrdctr
That HP-35 is a piece of history. A slide rule is like a Dinosaur for the younger crowd. It is so old it is almost inconceivable! If you tell them that the early Apollo missions were done with slide rules they would not believe it. It is amazing when you think of it.
lc6
Apparently, to test power cords and isolation transformers, one needs to have this ~$30 gizmo instead of an expensive AP analyzer:
Monster Cable EnTech EMI Noise Analyzer Review
This is how effective it is in peddling $7,500 power cords:
"In a demonstration presented to a cluster of seated onlookers that included me, a representative of the company plugged a run-of-the-mill orange power cord into a Monster Entech Power Line Noise Analyzer (we all should have one), which is designed to measure noise on the AC line above 500kHz. I thought I'd run out of that room screaming (footnote 1). The noise was horrible—an intense barrage of static and hash. The rep then substituted a DR Acoustics Pegasus Extreme power cable ($7495) for the cheapo AC one and … nothing. As much as I pricked my ears in search of a murmur of grit, all I heard was myself breathing. It was an ear-opening presentation."
"The Monster Entech device is not a current commercial product, but they're relatively easy to find used or occasionally new. According to information I found online, this meter is sensitive to noise in the 300–700kHz range. The same, seemingly authoritative source says that the sound produced is 'amplified demodulated AM FM noise present on the power line under test.' The more energy there is in the band the detector is sensitive to, the louder the sound will be."
A combination of a few small inductors and caps would easily achieve the demonstrated filtration of power line noise above 500 kHz (notwithstanding the fact that such filtration is effectively carried out in a power supply of any decent piece of audio equipment anyway).
SuicideSquid
What a great example of the complete lack of any critical thinking ability on the part of people hocking (and being suckered by) these products.
Oh crap there's noise 20x the frequency of the audible spectrum?! We must spend $7,500 on a power cable to eliminate it (without ever considering whether such noise is already being filtered by the power supply or causing any audible issue whatsoever).
milosz
Chicago
Noise in the high kHz or RF frequency regimes can cause amplifier stages ( particularly solid state ones) to become unstable or saturate, and even though you can't hear the noise because it's above the range of human hearing, you can hear that said noise is causing gain stages in your gear to deviate from linearity. So, yes, even though you can't hear it, intrusion of EMI above the range of hearing can have deleterious effects on what you are listening to.
That said, any decent audio gear will shield the circuits from free-air ingress of ordinary levels of these signals, and the power supply in any decent gear will clean anything that gets transmitted through the power line. So one should not need any kind of outboard AC line filters or magical line cords.
HOWEVER - I know for a fact that noise signals in the environment can cause problems in audio equipment - I had an old NAD 7240 playing background music in my workshop, and I was testing a 2 meter (144 MHz) RF amplifier for use in amateur radio. I had the 400 watt 2 meter RF amplifier on my workbench connected to an appropriate Bird RF VHF dummy load and I switched the amplifier on to measure it's power output with a Bird RF power meter - as soon as I switched the RF amp on, the sound from the CD being played through the NAD 7240 got horribly distorted for just a second, then there was a POP through the speakers and then there was nothing coming out of the speakers. This all happened in less than a second. Of course I immediately turned off the RF amplifier, but by then it was too late- the output transistors in the NAD 7240 had opened up. The 144 MHz signal had got in to the amplifier stage and caused this failure. Now, this is an extreme case - there was a STRONG RF field in my workshop, which was probably picked up by the ~3 M of 14 AWG speaker cabling and delivered into the NAD. This won't happen in your listening room unless you are really near a fairly powerful operating transmitter - amateur radio or commercial broadcaster - but it demonstrates that not EVERY kind of EM interference is of no consequence to an audio system.
But - hahahaha - magic line cords and / or power conditioner boxes would not have prevented the death of my old NAD 7240. I doubt that shielded speaker cables would have helped either, as the voice coils of the speakers themselves would have likely coupled enough of this EMI into the NAD to drive it crazy.
POOF! It lasted 30 years of college, apartments, houses, parties, and workshop background music but that 144 MHz field was too much for it. But, as consolation, I got a documented incident of EMI having an impact on audio gear....
