AVR/AMP for Kef R3
chestera
I'm planning on setting up a 3.1 system using a Kef R3s, R2c, and a Rythmik sub. I'm trying to decide right now on an AVR or AVR + Stereo AMP for better music quality. Does anyone have any suggestions under $1500?
I was eyeing a few options like the Denon AVR x3700h (refurb) for just an AVR, or do something cheaper like a Marantz NR1711 ($750 refurb) + some type of stereo amp using HT bypass.
HarmonicTHD
Go for the X3700. The X3700 measures great (ca 90dB SINAD using the built in amp or about 100dB using only the preamp which does not affect any music reproduction audibly - see this forum on audiability of distortions and noise) and has XT32 room correction. Plus a ton of convenience features
tifune
Agree w the 3700 recommendation; I'd put forth the 4700 if you can squeeze it because it'll give you access to Auro should you choose to add speakers down the line. Crossed over at 80Hz for your sub, it will almost certainly get loud enough . R2c can beat up an AVR amp, though. How far will you be sitting?
Also can add Audyssey XT which looks promising, although licensing restrictions are so draconian that I probably won't buy it on principle alone.
