B&W PX8 headphones
Dimitrov
Has anyone bought these or had a chance to listen to them? What were your impressions?
I also don't know if there are any technical measurements available on these cans yet. Would be interested to hear listener feedback from users.
Elitzur–Vaidman
Measurements don't look great, but idk the difference between the PX and the PX8
metasharp
September 24, 2020 graph, no way it's the PX8 or even PX7 or P7. It's probably, as written, the regular old PX model from 2018.
staticV3
Here are GRAS 43AG measurements of the PX8:
Typical Sony-ish consumer tuning :(
MayaTlab
I can confirm that their sound changes a lot depending on position / compression in the 1-5kHz range, like quite a few ANC headphones. Also the earcups can't angle upwards enough for my head, meaning that most of the clamping force is applied at the top of the earcups and that it's quite susceptible to leakage in the bottom rear quadrant, reducing the effectiveness of the ANC and perhaps even defeating the feedback mechanism.
You now have the option in the app to EQ them a little bit (two bands), if the frequency / slope for the bass band matches the measurements, perhaps you can make the bass response align better with the Harman target ?
mrdrewk
I just got a pair of these. They are wireless Bluetooth and have no AUX in. No matter what you do, you have to use the onboard DAC. So, how does that DAC measure vs other DACs?
Oddly it has a 3.5mm > USB C cable that has a ADC in it. This will surely confuse the poop out of most buyers.
I still may sell these and go with the Focal Bathys, at least there I have the option of using onboard DAC or not.
Peterinvan
I downloaded v3.0.0 and set the EQ at -2db on the bass and +1db on the treble. This brought the mids a bit more forward and tightened up the bass.
Listening to the Android Tidal app, with ANC via aptXHD out of my FiiO M11Pro.
Now my old guy's ears are happy :)
I have ordered a low latency BT transmitter to see if there is any lag when watching TV.
Kal Rubinson
Industry Insider
NYC
I use the same settings but run it without NC and wired directly to my source by USB-C. Quite satisfying.
mikemachin
FR
Noticed that Tidal tends to emphasize the bass a little bit, you might want to try Qobuz. Not as user friendly but better equilibrium between all frequencies to my ears, with PX8 and others.
