- Joined
- Jun 10, 2018
- Messages
- 6,345
- Likes
- 9,499
- Thread Starter
- #41
OK, I noticed in REW there is a phase measurement. In my system it was around -175 degrees. I changed the phase switch on the sub to 180 and now the phase measurement is +5 degrees. It sounds better. Did I get it right?
One other thing. If you have a topping D30 using USB input make sure the Windows volume control is set to 100. Some wonky measurements are leading me to believe the digital volume control in the D30 has loudness compensation.
I would need some different hardware to have multiple subs with separate EQ. It's just not something I want to try right now.
ASR is really great. There are bunches of smart and knowledgeable people here.
