- Joined
- Dec 9, 2020
- Messages
- 374
- Likes
- 749
Here are my measurements of the Behringer ADA8200 Ultragain we purchased for the studio 6 years ago. Current price I see on Thomann Germany is 220€.
The unit is digitally fed by our RME Fireface UC and analog I/O consists of a Topping EX5 and a Cosmos ADC.
Let's start with the DAC part:
-0.5dB points are 3Hz and ~20KHz
Noise spectrum reveals -86dB THD+N at 3.7V (0dBFS):
I forgot to properly measure dynamic range but as you can see, it's at least 99dB.
Distortion vs level:
ADC Mic Input:
Frequency response:
-0.5dB points at 8Hz and ~22KHz
Noise spectrum at best-case SINAD (87,5dB):
ADC Line Input:
Frequency response:
-0.5dB points at 3Hz and ~22KHz
Distortion spectrum at best case SINAD (86dB):
As you can see I used 18dB of gain to be able to make the input clip with the EX5's output capabilities, pointing at an un-gained clipping point of 33dBu (34,5Vrms wow!). For reference, that equates to about 150W into an 8 Ohm load.
I did not measure its performance with a simulated microphone 'load' on the input.
I swept the Mic input for distortion vs frequency and found it to be pretty much the same level and characteristic throughout the entire spectrum, being dominated by the 3rd harmonic.
Summary:
All in all, you get pretty good performance for little money and you just need an ADAT bridge to be able to use this as an 8In 8Out interface.
Both for the DAC and the ADC side, distortion is pretty much a non-concern, but noise isn't the cleanest. For DAC applications you should aim for good gain staging in your chain or you might end up having hiss issues.
For the ADC, you might encounter noise issues here too, depending on what you're recording. You have the noise floor at ~-100dB, but you leave let's say 20dB of headroom for good measure and your dynamic range is already below that of what 16 bit audio can handle. Add compression to that and record more than one channel and noise might become an audible issue. This however can easily be resolved with a noise gate or through spectral editing.
We use it mostly for drum (shell) mics and I haven't found myself wishing for a better signal yet. The usability however could be improved (by being able to control gain digitally from a PC and having more level indication LEDs than just "signal" and "clip").
For about 200 bucks you get great performance here. With the RME Digiface ADAT bridge and four of these, you can get a 32In 34Out audio interface for just a little over 1000€ here.
Cheers!
ADC Mic Input:
Frequency response:
ADC Line Input:
Frequency response:
Summary:
Cheers!
