Best amp to get 11 channels out of denon x4700H
Blue2kid3
Hi guys between the denon x4700h and x6700H I want a 7.2.4 atmos set up. I was hoping you guys could point me in the direction of a good 2 channel amp that would come in a bit under the price of an X6700H or do you think just keep it simple and go x6700H?
dk0r
...I don’t know if the Denon can run the LCR channels from an external amp...
@Alexanderc, why do you question whether the Denons can bypass it's internal amplifier and use an external amplifier?
For example, as depicted below, the x4700H has preamp outputs for all 7.4.2 channels which includes preamp outputs for the LCR in question.
I had assumed that the physical existence of the LCR preamp outputs implied an external amp could be used for LCR.
AdamG
Safari “Troll” hunts available at reasonable rates
Moderator
Reality
Welcome Aboard @dk0r.
dk0r
Perhaps @Alexanderc is referring to this post which indicates the X4700h can (only?) be set to either:
  1. Disable internal amplification for both the FL & FR channels
  2. Disable internal amplification for all channels
Update: Upon further inspection, it looks like the following thread outlines constraints on the X3700/4700h's ability to bypass internal amplification: So pre-amp mode only applies to the L and R channels? (2020 Denon/Marantz AVRs) Looking for some buying advice...
Alexanderc
Florida, USA
I just didn’t want to say, “yes, you can do it this way…” without actually being 100% sure.
