Best AVR DACs to date?
Descartes
Is there a ranking for the best AVR DACs my primary interest is multichannel audio music, then movies I almost never listen to stereo on my system!
staticV3
D
Descartes
The NAD M33 is not an AVR, unfortunately!
The NAD Master Series M17 V2i is but I don’t see any ASR reviews!
staticV3
@Descartes if you're playing your music and movies from a PC and can run your DSP on there, then you could use a Topping DM7 or Octo DAC8 as multichannel DAC. Those beat everything on the list above.
D
Descartes
That won’t give me ATMOS or Spacial Audio though! I have an OPPO UDP-205 but I don’t see myself changing the amplifier connections for movies and music.
Dougey_Jones
People make it seem like this is a worthwhile solution, but I've used an HTPC for twenty years and I'd still never do this.
funnychap
I upgraded from a Denon X3700H (terrible for music, ok for movies).
I love my Arcam AVR5 (great for movies and music and Apple Music spatial audio surround music via Dolby Atmos). The newer Arcam models that end in the number 1 (AVR11, AVR21, AVR31, AVR41) are even better because they have 2 ESS Sabre dacs.
delta76
how do you compare x3700h with AVR5? with your ears?
ArturoKiwi
A passive switch is a bad idea?
Between an avr and topping dx7+ pro or another one at your choice
staticV3
What is the most recent update
Here's the latest graph from Amir:
However, you could include some newer user measurements of the Monolith HTP-1 (link), which would push it near the top at 105dB SINAD:
Edit:
Also, since Amir counts the Flex as an AVR/AVP (debatable), one could place the new Flex HT/Flex HTx all the way at the top (link). No Flex version can decode Atmos, DD, etc though.
staticV3
If you're looking for the very best Atmos->Analog conversion and you don't care at all about all the other features that AVRs usually offer, then you could use an Arvus H2-4D and a bunch of standalone DACs with AES3 input (or two dac8 PROs for example).
It'd be expensive, a hassle to set up, and you'd be missing out on room correction etc, but you'd have SOTA Atmos->Analog.
ban25
Audioholics has bench tested the AV10 at 108 dB SINAD:
