best class d amp for 200 euros
TheBatsEar
Germany
Didn't know that one, bookmarked.
Where do you live? I'm in Germany and Ebay Kleinanzeigen is my main source of gear (and entertainment: Was letzte Preis?). This is on the market right now:
  1. 245€ VB: Receiver Yamaha R-S700 mit FB und BA, topgepflegt + revidiert
  2. 300€ FP: Yamaha R-S700 Verstärker / Receiver
  3. 333€ VB: Yamaha R-S 700 - Silber Niedersachsen
  4. 320€ VB: Yamaha R-S700 HiFi Anlage mit Magnat Boxen
  5. 240€ VB: Yamaha R-S 700 Reiceiver Verstärker silber
All of them, except the 330€ with the speakers, will ship. All of them, except the 300€ one (which is me), accept offers. Getting one of them to agree to 200€ should be possible.
Forget 4, i just bought that for 290€. I'll sell the speakers for 120€ and have payed 170€ for the A-S700. :cool:
I may use it in my Directiva build and sell the A-S300.
TheBatsEar
Germany
gasolin75
gasolin75
Denmark
I bought a yamaha amp im just waiting to collect
TheBatsEar
Germany
gasolin75
gasolin75
Denmark
unfortunally just a new amp.
I didn't liked a silver amp and wanted the option of returning it, i didn't find any fairly new "used" yamaha amp
The amp i bought has buy and try for 30 days so it doesn't costs extra to return. I did find a used Cambridge audio axa35 i considerede but it's silver only, i prefer black so it matches my Yamaha CD-S300, also i think i need altlest 50 watt pr channel in 8 ohm
Only alternative i could find used was a Yamaha WXA-50 and it lacks inputs so i had to use a phonostage and audio source selector
TheBatsEar
Germany
Right, right. But which amp did you get, my dude?
gasolin75
gasolin75
Denmark
Yamaha A-S301 MKII​
I should have it witin a hour
gasolin75
gasolin75
Denmark
Im just passioned about hifi
gasolin75
gasolin75
Denmark
First impression
It's big for the modest power it's got but i think it's an universial size,chassis for the 301,501 and 701, lots of air for the heat, after 30 half an hour not close to being warm
Volume knob is firm
A litte soft rear,back of the amp when connecting the banana plugs
10 o'clock using my yamaha cd-s300 and mission lx 2 theres a good match (canare 4s11 speaker cable,inakustik interconnects and isoacoustic stands), better bass, in direct mode the bass it's precise and firm, some improvement over class d, 10 o'clock eric clapton layla unplugged sounds balanced, more to the clear open sounding side of neutral than warm, it doesn't add any warmth to the sound if you don't play with the tonecontrols
Power 11 o'clock is adequate for loud music
Cons it's a little huge compared to Nad c316bee v2 and Marantz PM6007
TheBatsEar
Germany
Nice. Didn't know there was a MKII, what has changed?
If you decide to keep it, there is a mod where you can get pre-out/main-in to use it as a pre-apm, power-amp or loop in EQ/DSP. No need for much skill, all you need is a soldering iron.
TheBatsEar
Germany
Another thing, keep the resistance switch on the back on high, no matter what.
gasolin75
gasolin75
Denmark
I don't want and need pre out,main on the amp
Default is on high, why should i use high, i have 6 ohm speakers that goes down to 4.4 ohm
gasolin75
gasolin75
Denmark
In the start i thought the highs where somehow to much, now after some hours of music (stil very cool) the highs seems to have changed.
The phonostage is approved, pleasant to listen, it just works :)
TheBatsEar
Germany
  1. High means you use the higher voltage. This means that with 8ohm speakers you stay within the heat budget allotted to the size of the cooling fins. You get full power.
  2. Low means you use the lower voltage. It makes sure that you don't overstep the heat budget for the size of the cooling fins and not trip the heat protection turnoff. Power is limited.
Using high with a low impedance speaker means you might overstep the heat budget, if you listen at high power for very long time, and the heat protection turns you down, but you get the full power.
TheBatsEar
Germany
I'm a bit jealous, the variable loudness is a nifty feature i wish i had as well.
TheBatsEar
Germany
@dualazmak, if you dont mind, would you check if there is maybe some news about a Yamaha A-S301 MKII in Japan?
I doubt it, but they know first if something comes.
@gasolin75 , check the back if it says MKII indeed.
gasolin75
gasolin75
Denmark
Absolutely no heat problems
