Best closed headphone
KeithPhantom
WoodyLuvr
Siam
Concur on B&O H6 v1; a surprisingly excellent closed back headphone punching well above it's pricing tier
evernessince
I have a pair of Aeon Flow Closed and just ordered a pair of Focal Elegia. I can let you know how they compare if you wish.
ShiZo
I love my elegia and have tried many. Only competitors I think, even though I haven't heard them, should be aeon 2 closed and the stellia.
Nemo
Spain
Hello,
I am very happy with my HD650 but the wife is not happy about the noise...
What would you recommend?
I am thinking of three headphones: dt1790 pro (USD 400), MrSpeaker Ether CX (USD 750) and HD820 (USD 1300). What am I missing?
The set up is THX 789 and Topping D70. All I need is a neutral headphone.
Thanks.
I was in a very similar situation myself, and got the Ether CX. I found them bass-light initially, but with one of the supplied pads I find their balance very neutral, which is important for me as well (Topping D50s > TCA HPA-1). They are heavier and less comfortable than the HD600 though.
I also have Ultimate Ears Reference Monitors, which are another flavor of neutral if I may say so, and my problem with them was that putting them on-off to be able to maintain a short conversation was (is) a pain.
A word of caution, though: I do not listen at high volumes, but due to the pandemic work-from-home situation, my wife sometimes ask me to stop using the Ethers (that leak a bit) and use the UERM instead that are completely silent to the outside world.
Good luck,
ShiZo
Elegia has no much sound leakage. Ive always wanted to listen to the ether cx's though.
marv
This i really need to know as i would be using them in recording/silent environment in case i get them... please keep us posted
ShiZo
There is leakage but it's extremely minimal. Blasting it someone might hear barely what you are listening to.
evernessince
So I got extremely lucky and had my Elegia delivered to me today. I had a good amount of time of time with them listening to a variety of music (everything from classical to pop to funk to FLAC video game soundtracks). I also tried them in a few games as well.
First things first. ShiZo is correct, there is indeed minimal leakage. At normal listening volume you can barely hear them 1 ft away. That said, the Aeon Flow Closed have slightly less leakage than the Elegia's.
I'm sure this has been said before but the included cable is short and tangles easily. Short as in your DAC/AMP better be right on your desk or it won't reach.
The Elegia are very easy to drive. If I set the volume to 25% on my JDS Labs Element (low gain), that's enough for optimal listening. The Aeon Flow Closed require somewhere around 40%, just for comparison.
Comfort wise the Elegia are surprisingly good. Not too much clamping force and didn't feel too heavy. The Aeon Flow Closed feels like a light fluffy pillow though. Hard to beat that level of comfort.
Sound isolation (not to be mistake for leakage) for either the Elegia or Aeon Flow Closed are about the same. They don't provide a ton of isolation. Mostly mid frequencies, voices and the like.
The bass was fantastic. A lot of people say the Elegia are base light but to me it seems like they have the perfect amount. The quality of which was exceptional as well. Compared to the Aeon Flow Closed, they provide a bit more oomph exactly where it's needed over the Aeon Flow Closed without making other parts of the song over-done when they shouldn't be. Both have tight controlled base with excellent extension into the lower frequencies but the Elegia gets the win here.
Mids are a sticking point for the Elegia. There were some songs that sound significantly different and not always in a good way. I found multiple songs were the mids took over the presentation of the song and drowned out other instruments or sounds. They were still there but you really had to listen to hear them. In my opinion the Aeon Flow Closed provided a clearer, neutral presentation. I should state that both overall had excellent detail.
Treble wise, the Elegia sounded good, except it lacked any punch. I consider the Aeon Flow closed to not have amazing sparkle but the Elegia have even less punch then that. I vastly preferred the ATH-A2000Z over either of these in this category (that's about the only thing those cans did exceptional though).
For Imaging I felt the Elegia had some idiosyncrasies. If a sound was moving from one channel to the other, for me it was hard to locate it's precise location when in the center. Still excellent overall but not as good as the Aeon Flow Closed.
Last is soundstage. I felt the Elegia had a wider soundstage then the Aeon Flow Closed. Not by much but perceptible. I also felt that sounds coming from the sides and behind were slightly easier to place in games. This benefit didn't really manifest in the music I tested. I'd give the slight edge to the Elegia in this category.
If you were to ask me which I'd prefer, it'd be the Aeon Flow Closed. That said you really can't go wrong with either option.
F1308
Any idea about the V-Moda M-200 performance, please ? Thanks....
ShiZo
Do you have the original aeon or 2, also what I'm curious your source gear.
raistlin65
Grand Rapids, MI
This! Absolutely love my Elegia.
Maybe a touch light on bass but have a glorious midrange (where all the magic happens!).
Me too. I recently got them with the Adorama deal. Added +1.5 to 2db across sub-bass and midbass frequencies, and now they sound very good to me. I love them with all kinds of rock.
evernessince
Sorry, I've never tried those.
I have the aeon flow closed. Not the original aeon or the aeon 2s. The flows are a small upgrade over the original.
My DAC / AMP is the JDS labs Element.
