slave of JESUS
- Joined
- Aug 29, 2022
- Messages
- 16
- Likes
- 2
What is the best DAC-headphones combo for A90 under 2k in terms of detailt retrival and transparency specifically on mid's and high's?
Thanks!
Thanks!
Thank YOU for YOUR response!Senn HD800's top most lists.
I'd go with the HD80's and a A30Pro. I use a A30 Pro and HD6xx from drop.Thank YOU for YOUR response!
No doubt!But they more than 1.5k alone!
And the question about DAC-headphones combo for under 2k.
Actually several people do A/B with 1990 and 800's say that they about 10% better than 1990 in terms of clarity while having triple price!
Perfect opinion!You totally RIGHT!I'd go with the HD80's and a A30Pro. I use a A30 Pro and HD6xx from drop.
But i already have A90.So i need DAC-headphones stack for him under 1.5k with detail retrival priority
You absolutely RIGHT SIR!hmm sounds like you've done things a bit backwards. You're going to want a DAC that can drive that A90. Others here I'm sure can help with that.
Yes its a problem. I'm waiting 10 months for speakers I ordered.You absolutely RIGHT SIR!
What exactly you mean SIR?Create new thread?Others here I'm sure can help with that.
Topping D10 balanced for the DAC- Dan Clarke audio Aeon 2 Noire for headphones (order with a balanced cable)- job doneThank YOU for YOUR response!
And the question about best DAC-headphones combo for A90 under 2k.
0.5k for A90 and 1.5k for DAC and headphones.2k in total.
I already have A90.
That's exactly what i am asking.So the best combo for A90 is D90SE(LE)?You need a DAC that will drive the A90 to get decent levels. Ideally that would have been the D90SE. That won't leave much budget for headphones.
THANK YOU FOR YOUR RESPONSE SIR!Topping D10 balanced for the DAC- Dan Clarke audio Aeon 2 Noire for headphones (order with a balanced cable)- job done
I don't know the X16.That's exactly what i am asking.So the best combo for A90 is D90SE(LE)?
What you think about X16 instead of 90SE(LE) with A90?
Will that fully drive a A90?Topping D10 balanced
How do you mean? It's a 4v dac if you connect it balanced. https://www.audiosciencereview.com/...d10-balanced-review-usb-dac.25094/post-852298Will that fully drive a A90?
Okay, cool. He'll want balanced for sure.How do you mean? It's a 4v dac if you connect it balanced. https://www.audiosciencereview.com/...d10-balanced-review-usb-dac.25094/post-852298
The DAC doesn't drive the amp, and even if the A90 can take higher input voltage than 4v, it should still be able to amply drive almost all headphones using only 4v input. I doubt the op is looking at Susvara and the like.
