juliangst
Hey,
I just tried to correct my LS50 using REW and my Behringer ECM-8000 to get a flatter response. I set the volume to roughly 75dB using the pink noise generator.
I only corrected peaks which are mainly caused by room modes in my setup.
I used the following settings for the filter calculation:
Before and after results (green: no correction; blue: with correction):
The room correction definietly fixed those bass peaks. I also tried to correct that dip in the 2-3kHz range but wasn't happy with the results so I sticked with this correction filter.
The problem I have with this correction is that the system now lacks bass and punch and sounds 'lifeless' if that makes any sense.
Am I just used to the old non-corrected sound of my LS50?
Should I also allow for boost in those trough areas?
Did I do this room EQ correctly or are there any things that I missed out?
I hope someone can help me with my situation. Thanks in advance!
