So we like to measure and rank DAC's with regards to their SINAD, regardless of whether the differences can be heard.
But what about speaker cables, they also have specs, also regardless of whether the differences ca be heard
If you want the audio components with the best specs, then you would probably also like the best speaker cables....
So which speaker cables are the best with regards to Resistance/Capacitance/Inductance/Other ?
Is it Canare two wire 12AWG (*) or Supra Ply 2.0 (**) or ?????
(*) https://www.audiosciencereview.com/forum/index.php?threads/when-12-gauge-wire-is-not-12-gauge.3/
(**) https://www.stereophile.com/content/what-difference-wire-makes
