Beta-test: DeltaWave Null Comparison software
pma
Prague
After setting Cosmos in the Control Panel to "stereo" (slider 40%) the issue has gone.
My original intent was to put NC252MP into the loop and make an ABX test vs. original file. It was delayed by my Cosmos setting mistake. Now I have put the NC252MP into the D10s==>Cosmos loop - and the difference against the original file is, as expected, negligible and not detectable in the ABX test.
slartibart
Thanks, looks like there is a clock drift (which is expected when you use two separate units with separate clocks). Because there are a few portions of the file that are almost an exact match (in the frequency domain) to other parts of the file, with just a different amplitude, this causes DW to think it's a simple periodic waveform (measurement waveform prompt). I just tell it that it's not, and it continues fine.
Here's the first file result with clock drift correction for mpd2:
Here's the match for mpd3. Note that mpd3 recording started a number of seconds earlier than the reference, so I trimmed two seconds off the front by setting Trim Front to 2. DeltaWave finds the initial delay mismatch if it's within about 2x the FFT size number of samples. If it's more than that, you need to trim one of the files to get them to at most a few second delay between them:
And here are the settings I used with both files:
Your results show a fairly big difference for mpd2 and mpd3 which was really my question. mpd2 and mpd3 are two recordings of the same signal but the results are very different. Why do you think that is?
pkane
pkane
North-East
There’s a large difference in clock drift between the two, but to see things more clearly it might help to compare the two recordings to each other rather than to the original reference.
slartibart
I did manage one capture where the Spectrum of delta was -110dB. The clock drift in that case was very low so I suppose the trick is to repeat until you get a low clock drift.
pkane
pkane
North-East
View attachment 253891View attachment 253892
That indicates that the clocks are not running at a constant rate relative to each other with enough variation between captures to cause these differences.
MC_RME
this is not my idea, ESS made that this way
And I like it the way it works. In mono mode we are forced to use an y-adapter so that both inputs get the same signal. This also means that you can easily compare the advantage of mono mode for the current test signal by just looking at left and right input values - provided the software that you use measures in 2-channel (stereo) mode. It also makes clear quickly that both inputs do get a valid signal (cabling etc. correct). Both points would be missed with the right output channel muted.
pkane
pkane
North-East
Updated to the latest version and there seem to be something missing:
Try uninstall, re-download, then re-install. I just tried a clean re-install and had no issues. Check your antivirus to see if it's blocking some part of the install.
Dilettante
Fixed. Turns out the problem shows only if installing over an older version.
Zensō
California
I've yet to try Crossover, but it was reported to work. I usually use Windows running in a VMWare Fusion virtual machine.
I tried Crossover and was able to load DeltaWave, but it would only partially load the files then lock up. I may give Fusion a try. Thanks!
Rantapossu
Should the compare-file be aligned against the reference-file and not the other way around, as it seems to be now?
When you select the reference-file and export it before the matching and export it again after the matching, the alignment has changed:
The reference-file after the matching seems to be otherwise a bit perfect copy of the original reference-file, but it seems to be about 17000 samples off-aligned (In my case, of course this changes regarding the sound card and buffers used).
The trimming is disabled, so it shouldn't affect the end result:
Is this happening because there's no enough recorded signal in the beginning of the compare-file (After the delays caused by the sound card buffers and other factors) and that's why DW shortens the beginning of the reference-file? If so, could there be a for example two second digital silence added in the beginning when playing the reference-file and then there would be enough data to trim the start of the comparison-file instead the reference-file? So play 2 second silence and the original reference file combined and compare the recording to the original reference file without silence delay. Then there would be almost certainly enough data recorded.
In my opinion DW should never touch the reference-file and do all the alignment and other magic only to the compare-file.
Grooved
The reference-file after the matching seems to be a bit perfect copy of the original reference-file, but seems to be about 17000 samples off-aligned (In my case, of course this changes regarding the sound card and buffers used).
In my opinion DW should never touch the reference-file and do all the alignment and other magic only to the compare-file...
Never saw that it can change the reference file.
Just a question, can you check if your reference-file was longer than your compare-file before the first test, please?
Rantapossu
I edited my previous question after your posting:
Yes, the reference-file after the matching and the compare-file is about 17000 samples shorter than the original untouched reference-file. So it's most likely because the delay of the sound card buffers and there wasn't enough data to compare. So DW trimmed the reference file to match the start of the recorded compare-file.
Rantapossu
And to be clear, DW doesn't alter the original file which is loaded as a reference from your drive, only the file you can export from DW (before and after the match) from the menu. So there's no fear of ruining your originals...
pkane
pkane
North-East
Depends on what's in your file. If it's a simple test signal, it'll most likely periodic and DW may find perfect matches at different portion of the file than just at the beginning. A decent length music file is best. Otherwise, you may need to turn on the 'measure simple waveforms' option. But that is also not a guarantee that the two waveforms don't match perfectly somewhere other than at the start.
Rantapossu
My file is a 30 second piece of normal music.
To test my theory I turned off the automatic matching and compensated the missing samples of the compare-file (Due to sound card buffers etc.) by adding 2 seconds of digital silence to the start of the compare-file before pressing manually the Match-button. And now all 3 files are perfectly aligned after the match:
@pkane could it be possible to add a certain amount of silence before playing the reference file and compare the recording to the reference file without the silence? I have tried DW with three computers and all of them trim the reference file from the start. This change would solve the problem...
Rantapossu
I managed to find the reason why DW sometimes trims the start of the reference-file and doesn't adjust the compare-file instead like it should. There are about 17000 samples of digital silence in the beginning of my test track and the "No-sound" -detection doesn't start the recording until the signal is above the set treshold. The start of the song was ignored in the recording and DW trimmed the reference-file to match the 17000 samples shorter compare-file.
So even if you add 2 seconds silence in the beginning of the track, the recording starts only after 2.4 seconds after the start of the playback. So my above suggestion about adding the silence for the playback is a no-go on its own.
A lot of my tracks start with a digital silence (Like many other digitally created songs do) and when I replaced the first 100 ms of the silence with a -50 dBFS white noise, the playback and recording started at the same time because the "No-sound" -detection triggered immediately. DW didn't trim the reference-file and the compare-file was aligned perfectly.
@pkane would it be too hard to create a settings option to turn off the "No-sound" -detection? I would greatly appreciate it...
pkane
pkane
North-East
Sorry, I didn’t understand that you were losing samples during recording and not during the alignment process. Recording is a bit tricky since the playback/record loop will have some inherent delays that will result in variable length mismatch at the start of the recording, so this part gets removed automatically. While I can add an option to not trim, this will very likely add to the null error.
