- Thread Starter
- #41
What revels?My HT mains are Revels,
Maybe this correlates with my "no bass" impressions.They sound too "small" from a mid to farfield distance, like the entire sound is coming from one tiny spot.
F226Be. Of course plenty has been said about Revels on this forum. I'll just say I think of them as wide dispersion monitors. Perfect for me.What revels?
@neg, I have been deciding between 8330A (they should sound similar to 8030C) and 8341A, so it seems to be close to one of your options. Finally, I went with 8341A, you can read more about it in this post. In short, they are more musical to me.My preferable budget for speakers itself 2-5k$. The cost of amplifiers can not be taken into account in any way I can get it for 0$ sort of.
Thank you. Some time ago I find out that genelecs allow you to save all settings internally, so it's totally ok.GLM is a must though I'd say. I understand your working environment is Linux but you can always run the GLM software in a virtual machine. Also, it is not required to keep it up and running all the time if you are not going to control speakers with GLM (which can be quite convenient btw e.g. turning off/on a subwoofer with just a click). For the calibration functionality, the GLM software can be closed after the calibration as calibration settings are saved to speakers and they become "autonomous" in regards to using those settings.
I have more than enough space for 8351B. Also there is a plan to put them on racks with vibration decoupling. I'll do it for the current 8030с.Reading people's opinions, I'd have got 8351B though if I could have put them behind my desk otherwise they look simply too large for standing on a usual desk.
With the Ones (8x31) this goal looks achievable. My listening experience with 8341A resembles that one with Sennheiser HD 800 (and Lynx Hilo as DAC), and HD 800 are famous for a very detailed and wide sound stage.My goal is to get a sound that resembles in quality the sound of good headphones.
You sure your not hearing the distortion, 36hz? Your ears are at least 20db more sensitive at 36hz so at 1% distortion (very possible because your probably at quite a high level to hear those tones) your probably hearing mostly 36hz.Using a tone generator I can hear from 18 Hz on my Genelec 7360A.
Modern isodynamic headphones are more detailed. Worthy examples for my taste are dan clark expanse, dan clark stealth, snorry nm-1, hifiman he-6(old).With the Ones (8x31) this goal looks achievable. My listening experience with 8341A resembles that one with Sennheiser HD 800 (and Lynx Hilo as DAC), and HD 800 are famous for a very detailed and wide sound stage.
That’s quite possible as that was a quick and dirty test.You sure your not hearing the distortion, 36hz? Your ears are at least 20db more sensitive at 36hz so at 1% distortion (very possible because your probably at quite a high level to hear those tones) your probably hearing mostly 36hz.
If one is willing to do a little work you’ve pretty much laid it out for us.Subwoofers are not a hard requirement, but they make any system better.
1. Less distortion from the speakers, because the lowest 2 octaves are handled by the sub.
2. More outright bass extension.
3. Less compromise of bass quality due to room modes. In most rooms, moving up to 2 subs is highly beneficial as well.
With a $5K budget I would do a miniDSP Flex (with balanced IO, measurement mic, and Dirac license) for $844, a pair of SVS SB-2000 for $950, KEF R3 for $1500, and your choice of amp. Personally, I would go Hypex NC252MP.
miniDSP Flex
Pocket size processor with flexible Input/Output configuration, Audiophile converters, 400MHz Sharc DSP processor, BT connectivity, DSP toolbox for subwoofer and multiway crossover, Dirac Live optional upgradewww.minidsp.com
SB-2000 - Black Ash - Outlet
Learn about the SB-2000 Subwoofer with 500 watts power and our 12-inch driver. High performance and compact sound for your home audio system.www.svsound.com
Accessories4less: High End Audio at Low End Prices!
www.accessories4less.com
Buckeye Amps
Buckeye Amps utilizes the most advanced audio amplifier technologies available. Authorized seller for Hypex and Purifi Class D amplifiers. Based in the US. Free shipping and worldwide service!www.buckeyeamp.com
I assume as a Linux user you don't mind a bit of tweaking, you should be able to get sound quality on par or exceeding the D&D 8C with this setup. Just need to do some measurements to find the best subwoofer locations, then time align + add high-pass to the speakers.
You do not need GLM always on. You calibrate, save and disconnect if you wish.As far as I do not have any DSP right now I do not understand some things. Setup something with windows/mac laptop and use later with saving "dsp profile". But it seems that with genelecs I need GLM always on, it's not seem acceptable.
I personally love Inade, but whole Crackling the anonymous Sounds like passed through some colored DAC or something that adds that digital low level noise at high frequencies, imo. So.. Your genelec were probably right! And it probably means that Dutches can color the Sound a bit (at least one mastering engineer told me that opinion, and he ows 8351s). Regarding Inade - Colliding Domensions Sounds way More hifi with a ton of details imoI'm not sure what I've missing but dd 8c sounded far more dynamic and detailed. For example I run on it Inade - Disconnected States on it. It sounded more "fresh" with better treble or something and overall listening experience is more pleasurable. Also I liked how precise spatial response is. Moreover I just can run any music on it and it sounds great. For me genelecs sounded nice and relaxed but not very detailed in comparison.
Wow. I envy your ability to choose among the very best speaker designs. You’d really have to audition the KEF R3s in your space to “know” if the will give you what you want. I’ve heard them… they are great and kind of wish I bought them instead of the ELACs I did purchase. But next week something else will be the best speaker ever. As far as amp costs on a passive vs. an active, that’s really up to you. My guess is you could put a a Buckeye 2 channel amp in the mix for very little $$$ based on your speaker choice and it would completely rock. Subs… I really like them. Two subs… sure if you got the money. I personally find this notion you HAVE to play 2 subs a bit ridiculous unless you have a giant room.I am listening audio with some headphones, dan clark expanse most of time.
But sometimes this is inconvenient, so I have near-field speakers.
For now I have genelec 8030c. They sound good enough, but there is better options. For example I've listened to Dutch & Dutch 8c. DD are far away better for me with it pin-point location of all sound, better bass, better low-level sounds, more fun, also it supports rew, which support linux, etc. But there is pascal amp in the internals.
I heard that he is not very reliable and at least I do not want to risk it. Its formal parameters are also not the best, but I don't care. For this price tag I consider such risk is not very acceptable.
The question is what are the options to get the better sound. Obviously, for optimal results, I need a subwoofer,
or speakers that give good bass, such as dd. But I feel that dynamic range and low-level signals of my 8030c are
also not so good as in 8c at least and want something better in this sense.
My requirements:
- Near field
- I don't need extreme SPL, not a big fan of it also. If the speakers only play well at high volume, which is often the case, this is not my choice.
- No proprietary DSP things like genelec 83* or way to get reasonable alternative for it. I need support for linux because of it's my desktop.
- Subwoofer is ok, but two subwoofers 9k$ like genelecs are not ok))
Is the KEF R3 good option? Is it feels "fast" enough? I feel 8c fast and fun at for example, but many of another speakers are not, it feels boring for me.
Is the 8331 genelecs with this price a good option in my case? I will pay for dsp that I cannot use after all.
Do I enforced to pay (1-2)x 9k$ to get good subwoofer?
I listened to dutch and dutch with my friend again. This time it seemed to both of us that their mids were unpleasant, they almost always seemed to be "brighter" than they should be. This was especially noticeable on the vocals. We listened to Cesaria Evora. I don't know this artist well, but I have listened to this track on other good enough systems. Usually it sounded okay. Not so in dd 8c. Vocals are metallic so to speak. It's very strange to hear it in music like that. In my previous 8030c it sounds nice. Maybe it's some distortion or something. In fact, it seemed to me the first time when I listened to the algorithm it was like there were "too much" metallic plates and sounds "small" in the same time. But then I thought that it should be so. And now it doesn't seem that way. The speaker layout was slightly different, but the showroom was the same.I personally love Inade, but whole Crackling the anonymous Sounds like passed through some colored DAC or something that adds that digital low level noise at high frequencies, imo. So.. Your genelec were probably right! And it probably means that Dutches can color the Sound a bit (at least one mastering engineer told me that opinion, and he ows 8351s). Regarding Inade - Colliding Domensions Sounds way More hifi with a ton of details imo
There is a huge difference in price and size between a 8030 and a D&D 8c. Do you have a budget?I am listening audio with some headphones, dan clark expanse most of time.
My requirements:
- Near field
When I listened to them for the first time, I didn't think about buying expensive speakers at all, it happened by accident. Well, now as I use my acoustics more and more, my willingness to spend money in this direction is becoming wider and wider.There is a huge difference in price and size between a 8030 and a D&D 8c. Do you have a budget?
