DVDdoug
- Joined
- May 27, 2021
- Messages
- 3,033
- Likes
- 3,995
Nice job on the experiment!!!
But it would be helpful if you could translate what you heard into meaningful terms. i.e Frequency response and distortion. I assume there was no audible background noise from either amplifier since you didn't mention noise.
The difficulty with pink noise is that it's noise... There is randomness so readings are not constant so it's hard to get a constant-repeatable reading. You'd need some kind of longer-term averaged measurement.
BTW - Normally in an ABX test you are allowed to take as much time as you want and you are allowed to request "A", "B", or "X" as many times as you want before you "lock-in" your answer, or just give-up and guess.
I have a meter with a similar limitation. My meter is auto-ranging and it's OK with low DC voltages and it shows resolution of 0.1V (maybe lower with DC). But I think there's a diode for AC which means about a 0.7V loss (or 1.4V if it's a full-wave rectifier) and non-linearity and you can't read anything below the diode-drop. Just recently I bought a "better" meter.It seems I'm constrained via this particular meter to those two options - 750 or 200 - when set to measure AC voltage.
110Hz should be OK unless one of the amplifiers has a dip or bump in the frequency response at that frequency. And if there is a difference.... Hey! You've found a true-difference between the amplifiers! But, you could check a couple of other frequencies. High frequencies can be "screwy" because of the reflections. I was doing some high-frequency experiments in my home office once (I think 5-10kHz) and just moving around behind the SPL meter changed the readings by several dB.You are right. 110Hz is not a good choice, pink noise would be much better.
Of course it's nice to get 100%, and you have to wonder if it's worth paying more, or switching amplifiers if you can't get it right 100% of the time. But, 14 out of 15 is literally "off the chart" (less than a 0.1% chance that you are guessing).(On trial two I'd initially guessed wrong, but immediately recognized the differences again between the preamps once the switching continued).
