"Breeze Audio" ES9038 ES9038PRO DAC
maxxevv
Think the one I linked in still hard to beat for value and on the surface, some measurements ( albeit for the 9018 chip).
Let me know if you're keen on it, perhaps can arrange something as I found that I can indeed add alternate shipping addresses for my Taobao account.
fvp
Wow, that write-up is quite extensive! Are you able to contact them and find out if they are willing to sell one to me at discount for review?
Hi,
I am new to this forum and to HI-FI sound. First of all, great reviews in this Forum. Good job!:)
I am researching to buy a HI-FI DAC with a reasonable price. After much research I ended-up in this thread. This DAC from TaoBao seems to be an excellent cost-benefit using the ES9038PRO. This is the first one from Aliexpress/TaoBao that I see with much detail about the components used and some reasoning.
I am new to the performance graphs and parameters. Have you checked out the ones provided in the description? Do they look good?
Thanks!
fvp
That's the generic board. No idea how well that performs.
The one I shared here a while ago runs off 6 opamp chips and uses dual toroidal transformers and the works. Although in my opinion it sounds very good, I have no idea how well it will measure though the seller has some measurement graphs on his listing.
https://item.taobao.com/item.htm?spm=a1z09.2.0.0.4f212e8d7BjKVG&id=520572954027&_u=p1u1q9kmbfe5
Hi maxxevv,
Great find in TaoBao, I usually check only Aliexpress.
Did you happen to open the DAC to see if the components in there are equal to the ones described in the product description? Any anomaly?
Short compiled list of what I could find after translating to English:
Japanese Nikko KG 10000uf capacitors
Sanyo 1000uf capacitor
Regulator LT1963
ELNA-AUDIO UK WEL resistors
German ROE (I don't know what this is)
ERO capacitors
Thanks!
Veri
Beware of fake (Elna / Sanyo / ...) capacitors. Even legit manufacturers are exposed to using them sometimes..
Reactions: fvp
maxxevv
Hi maxxevv,
Regulator LT1963
ERO capacitors
Thanks!
I did open it up to see, from what I saw, they seem to be there though I did not take a tally. But there are additional heatsinks on the "flagship version" that I opted so, so not everything was visible without touching those heatsinks.
Reactions: fvp
fvp
Ok, I think I might try this one. I am thinking to buy this DAC and add the diyinhk XU216 with the VU Meter Oled, and change the front panel to add the VU Meter.
Thanks for the help!
maxxevv
They are of completely different manufacture.
fvp
Some additional info, there is an other model possibly from the same manufacturer, with the mobile ess chip ES9038Q2M. Same "Breeze Audio" mark, display shows "weiliang audio" when switching on.
https://www.aliexpress.com/item/Wei...Bluetooth-5-0-support-DSD512/32905738923.html
I think Breeze Audio is the name some case manufacturer put in the aluminium case and sell it to different DAC manufactures. In the beginning of this thread there were some discussion about it.
The design of this one is much simpler with the ES9038Q2M instead of the ES9038PRO (and other parts). Although cheaper as consequence.
istinnstudio
ha, this is weird, I could not imagine this!
istinnstudio
Some products are being titled "Breeze audio & Weiliang audio" so there might be some kind of cooperation.
Bhargu
There are a lot of DACs on there that take Breeze Audio chassis and puts generic DAC boards in them. So, all of these looks the same, but sellers differ.
PS: As mentioned above, Breeze Audio sells Emory chassis too.
Alckimy
Hello
I are new to this forum
End my English is not good but I wanted to know if in the end someone can tell me how they go these Chinese dac sold on wings .. on paper they look great for that price
Alckimy
I hope someone makes a review ..... meanwhile you can tell me how it feels and if the sampling frequencies are those declared
thanks
maxxevv
This looks pretty interesting with the whole range of inputs that's built into it.
https://item.taobao.com/item.htm?spm=a1z0d.6639537.1997196601.4.46e47484cUQFGx&id=581859621280
And on a more budget and austere version:
https://item.taobao.com/item.htm?sp...3VUoqt&id=570081094982&ns=1&abbucket=3#detail
The measurements posted are for the chip, not the system. I am very dubious that it performs well.
maxxevv
Yes, I'm aware of that. I was just highlighting that its a feature rich set for not a lot of money.
Performance measurements are strictly an unknown at this point in time. I do not think it will be be SOTA performance but I have a hunch that it will at least not be a bottom of the heap measuring either.
So, it would be interesting if anything else can be dug up on the Chinese interwebs though.
Someone is sending one of these to me once he gets it.
