Brief description (with pictures) of my Touchscreen Pi based PicorePlayer streamer...
Berwhale
@tonycollinet - I have a RPi 4 sitting around doing nothing, you have inspired me to do something with it :)...
simbloke
North Wales, UK
Just impressed overall. Not sure I could make it work for me, but appreciate the time and effort you have gone to to make it work for you. Thaks for posting the thread- it has got me thinking about moving into the 21st century... :)
LMS works well on a NAS or something else that can run docker. Docker has made it a lot easier than it used to be.
Still, my server has a UPS, and I wouldn't want to run any DB on a machine that can lose power at any time.
I know people run LMS on the Pi with PiCorePlayer and other distros but it's not a path I would take.
tw99
West Berkshire, UK
Saw that when i first encountered the problem. It doesn’t fix it for me.
Odd. I've got a very similar setup - PI2 into an SHD.
I remembered that I'm also running the following script as "User Command #1" , which ensures that the SHD is turned on and visible before starting squeezelite on the PiCore. Without this I think it doesn't work if the PiCore is started up before the SHD.
#!/bin/sh if /usr/local/etc/init.d/squeezelite status ; then echo already running exit else echo not running # delete pidfile sudo /usr/local/etc/init.d/squeezelite stop fi while true do if squeezelite -l | egrep -ql "SHD" then sudo /usr/local/etc/init.d/squeezelite start exit else sleep 1 fi done
antcollinet
antcollinet
UK/Cheshire
I have a synology nas that can run docker. I've never successfully used docker to run anything despite multiple attempts. Any tutorial around that you know of?
Berwhale
New PiCorePlayer driving my Topping x50 stack...
I have LMS running in a Docker container on an Ubuntu Server virtual machine (FLAC files are hosted on a Synology NAS). The vm is hosted on my little Dell Optiplex Micro 7060 ESXi host. Getting the container deployed was easy because i'm using Dockstarter to manage Docker and containers - I just had to select LMS in the list of available containers in the Dockstarter GUI and recompose to have it deployed.
At this point, I couldn't get any sound out of PCP (through the DAC or headphone socket). It took me about an hour to work out I had port clashes with two other packages/containers running on my server. Port 9000 clashed with Portainer (a container management application) and port 9090 clashed with Cockpit (a system management application). I changed the ports for Portainer and Cockpit and left LMS with the defaults (LMS clients seem to expect this) and everything sprang into life.
Berwhale
I'm not entirely happy with the case I bought from PiHut. I found this one with an integrated power button (and GPIO board to run it)...
I've ordered it from CPC/Farnell in the UK... https://cpc.farnell.com/multicomp-p...case-power-button/dp/SC15215?CMP=TREML007-005
The picture/render on the CPC website doesn't look quite the same as one on the Pipad page, but the images in the data sheet do. I guess we'll see when it turns up (and goes back if it doesn't match the description on the data sheet!).
I also found the SmartiPi Touch Pro case which is nice and has lots of potential for modification, but it's expensive in the UK (£30) and only seems to be available in white...
simbloke
North Wales, UK
I have that one in white, also got it from CPC. I'm happy with it, quality is decent for the price.
Berwhale
Has anyone got CamillaDSP working with piCorePlayer? I found the SuperPlayer extension with provides a web GUI and also links to setup the back end. I will give it a shot when I have some time, I was just wondering if anyone else had got this working or knew a simpler way?
Reactions: MCH
somebodyelse
I've not got round to trying it, but that _is_ the simpler way, at least compared to earlier versions.
Berwhale
stemag
I installed Jesper Lykke's porting of CamillaDSP and CamillaGUI to piCorePlayer v8.2, and they both work quite well.
Beware that this porting of CamillaDSP works with piCorePlayer 32 bit version only.
Foxenfurter
London
If you are technically minded it is not that tricky to install 64 bit CamillaDSP. NB for the LMS plugin I had to abandon using CamillaDSP and have implemented PEQ via a plugin that wraps SoX instead. CamillaDSP was much easier to configure, but is really designed to integrated at Operating System Level, which meant I was fighting it shutting down between tracks on LMS.
My SqueezeDSP plugin is in beta on LMS if anyone is interested. It should run on anything better than a pi 3B (I had it running on a pi 3B but with lots of glitches).
Reactions: MCH
Pablopbb
Just curious about the portions talking about the server (LMS), and the fact that the OP mentions the locally stored files are on a NAS. Couldn't you just run LMS on the NAS? It seems the picoreplayer *can* be both server (LMS) and player (endpoint), but if all your files are stored and accessed from the NAS, couldn't you run the LMS there? And, importantly, isn't the NAS the box you probably want running almost 24/7 anyways? Reason I ask is b/c I already have all my files moved on to a celeron powered linux server running as my NAS with a 2TB drive for music files (I looked at plex for music and audio too). Besides the RPi endpoints, you can still get nifty Logitech endpoints on the used market.
For those that wonder what this buys you vs just network share or DLNA, the PiCorePLayer or other LMS / Squeeze based players have [limited] streaming clients on the same UI (Spotify, etc).
simbloke
North Wales, UK
Yes, it's quite common to do that. I run LMS on my home server in a Docker container. Many home NAS can also run Docker.
somebodyelse
Docker gets around the problem of some linux varieties moving onto new Perl versions before LMS supports them.
