Instar
- Joined
- May 8, 2020
- Messages
- 37
- Likes
- 72
Hello,
I am an audio user who enjoys listening to music in a small room in an apartment house. (W 3.2m * D 3.4m * H 2.4m)
I've been using speakers from Genelec 8030c, Genelec 8341a, JBL 705p, KEF R3, etc.
And until recently, the system was configured with KEF R3, Nad M10, and SVS SB1000 Dual.
My Room
Then I learned about Buchardt and became interested in the A500, so I bought it.
I felt like I needed to streamline the audio system and the A500 felt attractive because the Kii audio three or the Dutch&Dutch 8c were so expensive.
My first impression of the A500 The detail on the low frequencies was disappointing compared to the existing system.
In the case of the mid-range, it felt like there wasn't much difference compared to the KEF R3, but I felt a little farther away.
In the case of the high range, it was a bit irritating and bright.
I wanted to measure with REW + umik-1, but my umik-1 broke, so I couldn't measure.
I took the A500 to my acquaintance's house.
acquaintance's Room
My acquaintance has a Genelec 8351B and earthwork m30 mic.
There, detailed measurements and comparative listening were possible.
InRoom measurements / Brown : Buchardt A500, Purple : Genelec 8351B
Buchardt A500 THD
Genelec 8351B THD
As you can see, the A500's THD was too high.
Overall, THD is high.
In this part, I felt that the details of the low range were disappointing compared to when using the KEF R3 + SVS SB1000 Dual.
Of course, even though the distortion rate of THD in the low frequency band is high,
there are parts that are difficult for people to perceive, so it may be that people feel different.
But even taking that into account, the THD seems to be too high.
We also tried to measure the many master tunings the A500 boasts.
Basic master tuning (2.5 way 25hz)
Nearfield Studio tuning
3way tuning
Results of hearing about the three tunings
Basic master tuning is suitable for listening at low volumes.
3way tuning was fine for listening with a volume of about 80db. (Thoughts of my acquaintances)
My acquaintances say that the Buchardt A500 sounds good balance and is equipped with a lot of creative and diverse functions.
However, they think it is less cost effective when competing with split systems like speakers, subwoofers, and network players.
In this regard, I am somewhat the same.
After completing the measurements, I purchased the Genelec 8351B and then compared and listened to at home.
The result of listening to the A500 after listening to the 8351B
The A500's mid-range sounded a backed out, and the low frequencies were a unnatural.
But I thought the A500's sound wasn't bad overall.
I also checked the A500's iPhone calibration function and other network streaming and various functions, and it worked fine.
In conclusion, the A500 is a Compact all-in-one speaker with Not bad performance
But, I think it's a bit unsuitable for listening to music with more than 80db volume.
also, it has a problem of not overcoming physical limitations such as THD, and I think that this can be a big deal for users who used subwoofers.
However, users who have never heard of sub low may not be aware of this.
I think the A500 is a bit pricey when it competes with the Genelec 8030c/KEF R3 with a decent subwoofer, and split systems like network players.
But it doesn't look bad for users who want to be compact.
Personally, I think there will be a further leap forward by replacing the A500's woofer unit with a better quality unit and replacing the rear woofer with a sub-only unit.
If you have any questions, I will answer.
My Room
acquaintance's Room
Buchardt A500 THD
Genelec 8351B THD
3way tuning
