Buckeye Hypex NC252MP Amplifier Teardown
Buckeye Amps
Newbie question/clarification:
If I am using NL4 speakON jacks but the customer only wants one channel connected, I would connect to +1/-1, correct? This way an NL2 cable would work correctly?
Labjr
That sounds right.
Trdat
Yerevan "Sydney Born"
Can someone please tell me a little more about the extra wire that is connnected to the top of the XLR connector, the one that is bolted ? Some type of grounding. Where does it connect from to where(obviously I can see where its connected to) but I mean the purpose and in particular where from?
Also, there is the white and blue wire which is the negative and positive but the third wire which I am presuming is another type of grounding is not connected to the third slot(hole) but to the side with a female terminal connector. Can't that just go into the 3rd ground hole that's made for it? Or is this something different?
Labjr
The black wire is to connect Pin1(shield) of the XLR jack to chassis ground. The wire with the female terminal is the signal ground for one the of the amplifier channels. It has to go to ground also. Not Pin 1 of the XLR jack.
Trdat
Thanks for this. There is a few other threads that also go into detail regarding wrong wiring and you have explained it in simple form. Apprecaite the response I think it's fairly understandable.
nstzya
I really appreciate it!
If you had access to 502's and 252's and your LCR were 4ohm speakers, would you just use two 502's or three bridged 252's, knowing that the cost difference is actually cheaper using the 252's?
Or is the hair splitting of possible differences you outlined above negligible?
The other small consideration is the rest of my speakers are all run off 252's so if I did a bridged setup for the front I would be able to correctly set input sensitivity on my HTP-1 (whereas right now it's splitting the difference between Vrms of the 252s and 502s I'm using).
So... am I right to conclude that - in the special case where you have only 2Vrms limits on your preamp and/or DAC output section - it would seem that the bridged 252's with their 1.7 Vrms sensitivity might be the better option?? (rather than the 2.7Vrms sensitivity of the 502's)
Trdat
I've been reading more about XLR wiring and curious if I wire the Hypex module the way you have mentioned above does that mean I can use a typical XLR cable that is wired with the shield to pin 1? Why ask is because I see a lot of recommendations regarding XLR cable wiring and although I don't fully understand the amendments that need to be made such as wiring the shield to chassis ground rather than signal ground I am presuming that the above wiring will ensure that the shield wire will end up to the chassis right?
arczar
I have a similar question:
According to the document on the hypex website, the signal cable shield from the amplifier board should be connected to the housing (not to PIN 1). PIN 1 should also be connected to the case, but in a different place.
The question is: should these points be common to the L and R channels?
Or:
PIN 1 of L channel and PIN 1 of P channel to one place (in my photo the screw fixing the XLR socket) and the L channel screen and P channel screen to one place (e.g. bottom of the amplifier)
or maybe they should be 4 different points?
AdamG
Moderator
Reality
Or:
Welcome Aboard @arczar.
babadono
Pin 1 to chassis is the correct way to wire XLR connectors. Keep the inter chassis' current on the chassis. Not going into signal ground. Signal ground should only have one point of connection to the chassis and it is usually at the power supply.
Any doubts search the web for "Pin 1 problems".
Loron
Got my Christmas gift on Monday!!
A new Buckeye Amp 6 channels… yeah
This will replace my Sherwood Newcastle A965 that is driving my Atmos height speakers. When Dylan offers Purifi I might replace my Rotel RMB1585 for my main 5 channels.
Amp was packed real well in a heavy duty cardboard box. Very well done.
Lay out of the amp modules in the case have changed compared to when Amir reviewed this model. I won’t be able to switch the amp because I will be traveling to see my family for Christmas.
I am posting pictures of the amp. Can’t wait to audition.
Buckeye Amps
As promised, bare aluminum rolling out in my cases. Large first. Once my existing blanket order is filled on remaining Medium and Small cases those will be bare, too.
Doing my best to always improve for you all! Big thanks to this community.
nstzya
Bare aluminum? Is this in reference to the grounding point? Or something else?
Buckeye Amps
The inside bottom panel and inside back panel are no longer being powder coated, so it is the bare aluminum showing, which results in better grounding and heat transfer.
amper42
Nice pictures.
Buckeye Amps
Nice pictures. For your security I would suggest removing the first box picture that displays your name and address. With this data posted online anyone can see exactly where you live and that you have a nice audio system. You also disclose you will be traveling for Christmas. If you are not planning to be home with a shot gun during this time, I would remove the bread crumbs you are dropping. :D:p:oops::cool:
Jdunk54nl
Arizona
Really that is going to be Buckeye’s future career. Audiophile thief. He is just building his list of people that have his amps to keep him “in business” for the foreseeable future.
Really, what more can you expect from someone that lives in Ohio and has an amp brand of buckeye (I know he says he is really a Michigan fan….but a real Michigan fan could never do that ;) )
DonH56
Monument, CO
If that were true, I suggest he find better role models than he posted above... :)
Srrndhound
Industry Insider
The way I have them wired now is that Pin 3 (Vout Standby) from the first module is connected to the 12v relay then split coming off the relay going to each modules PS Enable. This way of wiring I confirmed with Hypex was OK (essentially one modules Vout Standby can be used to control the PS Enable of multiple modules).
I'm curious about the need for the relay. Why not just connect the DC trigger input jack directly to the PS Enable pin of each module? It will use less current (0.5 mA per module) than the relay coil, and saves the cost of the relay.
