- Joined
- Aug 12, 2022
- Messages
- 161
- Likes
- 134
I just received my 6 Channel Hypex amp from Buckeye and I immediately plugged it in. I'm running it through my Homemade ported Bookshelf speakers that measure +/- 2db from 60Hz-20K and are +/- 1db for most of it. I'm running Tidal through a USB Scarlet into minidsp 4x10 to process for the homemade sealed sub I'm using. The sub is being powered by a Crown Class D amplifier. I listened without the sub first. I was previously using a Parasound Zamp V3 on the main speakers.
The Buckeye is far better sounding. Yes, some of that is probably due to it having more power, but it is clearly cleaner and faster than the Parasound. I also like the top end of the Buckeye. Many Class D amps suffer in the upper registers but this one delivers clean power even as I turn it up really loud. The amp has more power than the speakers can handle. Transients are fast and clean with the driver settling time much faster to my ear (I haven't taken measurements, but I bet it would be clear with this amp). I will be using this amplifier as the driver for a project that will be tri-amped so I will be able to test all 6 channels.
The amplifier is really light. It only takes XLR in (which is fine for me). I like it's simplicity and it delivers the source true to form. I love a good clean amp and will probably be putting a dirty tube preamp in front of it at some point (sorry Amir!!) just to see what it does with some good distortion.
Cheers to Dylan at Buckeye. He was easy to deal with, delivered everything promptly and on time. He responded very quickly to emails. I think he's going to get very busy with these amplifiers as this one is probably the best sounding Class D I have heard.
