- Thread Starter
- #121
That's for sure the proper way to do it.Also have no idea of how you would do it by looking at the SPDIF waveform, maybe some smarter folks know.
I have checked synced by looking at DAC outputs on an oscilloscope while playing a 15 kHz tone. For example take the UL Mk5, route the SPDIF output to the CM6206 and the SPDIF output of the CM6206 to a DAC. Then play a 15 kHz to tone to an analog output and the SPDIF output of the UL Mk5. Observe the analog output of the UL Mk5 and the DAC being feed by the CM6206 on the scope, if they are sync'd you won't see any movement between the traces.
Can also run frequency sweeps using a loopback as timing reference and see if the phase response is stable.
Actually makes we want to try it on the S2 digital to see what it looks like.
Michael
However now I am curious and might give the oscilloscope method a try. If I remember correctly when I tapped a spdif signal in the past, obviously you see the bits toggling all the time but I think I could trigger it to see the rises and falls well defined. If this is true (I will recheck) I could tap both in/out spdifs simultaneously and see if they stay synced over time (?) (my cheapo scope is 2 channels).
Of course I am not going to open my Ultralite to do this, but I should have a spare DIY transmitter/receiver board, so I can use regular toslink connections to the Motu and tap the electric signal from the transmitter and receiver, or directly the coax out signal from the Motu. Just out of curiosity, to see if it works.
Would that be a valid evidence of shared clock?
PS: hm, now I don't know if the scope needs to trigger both signals independently. Well, will try to find out.
